Go to primary content
Oracle® Database Error Messages
12c Release 1 (12.1)
E49325-10
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
141 WLMD-02005 to WLMD-02019
WLMD-02005: Classifier {0} for PC {1} is too long.
Cause: The classifier for the specified performance class (PC) was too long.
Action: Shorten the classifier in the policy set.
WLMD-02006: Total classifier length for PC {0} is too large.
Cause: In aggregate the classifiers for this performance class (PC) were too long.
Action: Remove or shorten classifiers in the policy set.
WLMD-02011: The DBWLM application for the system {0} cannot be undeployed because it is still enabled.
Cause: The DBWLM application was undeployed when it was enabled.
Action: Disable the DBWLM application and then undeploy it.
WLMD-02014: Oracle Clusterware infrastructure has reported a failure.
Cause: There was a problem in the Oracle Clusterware.
Action: Check the exception and, if needed the Oracle Clusterware logs, and correct the issue reported there. Then enable Quality of Service Management (QoS) and retry this operation.
WLMD-02015: QoS configuration key {0} could not be retrieved.
Cause: The key did not exist in the Quality of Service Management (QoS) persistent storage.
Action: Contact Oracle Support Services for assistance.
WLMD-02017: Could not retrieve credential information for database {0}.
Cause: An attempt to open the database wallet and read the credential information failed.
Action: Re-enable the database for Quality of Service Management (QoS) from the associated Enterprise Manager console for that database.
WLMD-02018: The task {0} has failed to terminate.
Cause: This is an internal error.
Action: Please provide logs to Oracle Support Services. Quality of Service Management (QoS) restarted automatically.
WLMD-02019: Cluster {0} state change detected. The action requested may no longer be appropriate or possible.
Cause: There was a change to the Oracle Clusterware state since the action was recommended.
Action: Consider implementing actions from the current recommendation.
