WLMF-03002: The Quality of Service Management (QoS) user {0} is not authorized to perform this operation {1}.
Cause:
The Quality of Service Management (QoS) user did not have the persmission to perform this operation.
Action:
Check the JAVA security policy setup and grant the Quality of Service Management (QoS) user the appropriate security permission if it should have this permission. Otherwise, this is the expected behavior.
WLMF-03003: The Quality of Service Management (QoS) service user does not have permissions to get the JAVA security Subject associated with the current access control context {0}.
Cause:
The Quality of Service Management (QoS) service user did not have the permission to get the JAVA security Subject object within the current access control context.
Action:
Check the security policy setup and grant this user the permission if it should have this permission.
WLMF-03004: Version check failed or not performed. Operation could not be performed.
Cause:
The operation to exchange the supported version numbers between the server and the client had not been called or had failed.
Action:
This is an internal error. Contact Oracle Support Services for assistance.
WLMF-03005: Application .ear file is corrupt.
Cause:
Quality of Service Management (QoS) .ear file was corrupt.
Action:
WLMF-03006: Unsupported version. The client supports versions {0} to {1}.
Cause:
Version numbers supported in the client were not supported by this Quality of Service Management (QoS) service.
Action:
WLMF-03007: Required policy set does not exist.
Cause:
There was no policy set in persistent storage.
Action:
Create a new policy set.
WLMF-03008: Invalid argument. Argument {0} was provided with value {1}.
Cause:
The specified value of the argument was invalid.
Action:
Please contact Oracle Support Services.
WLMF-03009: The policy set is corrupt.
Cause:
The Quality of Service Management (QoS) policy set retrieved from persistent storage was corrupt.
Action:
Create a new policy set and enable Quality of Service Management (QoS).
WLMF-03010: There is no policy set in QoS persistent storage.
Cause:
The policy set was not found in Quality of Service Management (QoS) persistent storage.
Action:
WLMF-03011: QoS is not enabled.
Cause:
Quality of Service Management (QoS) was not enabled for this operation.
Action:
Enable Quality of Service Management (QoS) and retry the operation.
WLMF-03012: The component {0} tried to transition from state {1} to {2}, but the current state is {3}. This is illegal.
Cause:
Action:
Contact Oracle Support Services with trace information. Quality of Service Management (QoS) will restart automatically.
WLMF-03013: QoS implement action ID {0} has expired.
Cause:
The Quality of Service Management (QoS) implement action ID has expired.
Action:
Implement a current recommendation.
WLMF-03014: The What If Analysis could not be performed.
Cause:
Quality of Service Management (QoS) is unable to perform the What If Analysis because its timestamp is invalid or expired.
Action:
Perform another What If Analysis.
WLMF-03015: The action {0} is in progress and it will complete at {1}. The current time is {2}.
Cause:
Unable to execute the action because a previous action has not completed.
Action:
Wait until the current action is completed.
WLMF-03016: Internal error encountered.
Cause:
Action:
Contact Oracle Support Services with Quality of Service Management (QoS) log information. Clusterware has restarted Quality of Service Management (QoS) automatically.
WLMF-03017: The operating system has reported a failure.
Cause:
There was a problem in the operating system.
Action:
Check the exception and the accompanying error messages for details , and correct the issue. Then enable Quality of Service Management (QoS).
WLMF-03018: QoS service is not in the expected state.
Cause:
Quality of Service Management (QoS) was not in the correct state to perform the requested operation.
Action:
Retry the operation shortly.
WLMF-03019: Required library could not be loaded.
Cause:
A library which Quality of Service Management (QoS) depends upon could not be loaded.
Action:
Contact Oracle Support Services.
WLMF-03020: Requested action was not implemented.
Cause:
Quality of Service Management (QoS) detects a change in system state that invalidates the performance projections.
Action:
WLMF-03021: Persistent key {0} had invalid value.
Cause:
The service found a corrupt key value.
Action:
WLMF-03022: Policy set or policy corruption.
Cause:
The service has detected a corruption in the policy set or policy keys.
Action:
Push a new policy set and re-enable the service.
WLMF-03023: Persistent storage not found.
Cause:
The persistent storage could not be found.
Action:
WLMF-03024: Only the LOCAL parameter value is supported to enable DBWLM
Cause:
The GLOBAL parameter value was set to enable DBWLM.
Action:
WLMF-03025: Invalid argument. Argument {0} was provided with value {1} and it must be less than argument {2} with value {3}.
Cause:
Action:
