| Oracle® Healthcare Master Person Index Message Processing Reference Release 4.0 E68421-01 |
![]() Previous |
![]() Next |
This chapter provides information about the Oracle Healthcare Master Person Index (OHMPI) database, including descriptions of each table and a sample entity relationship diagram. All information in this chapter pertains to the default version of the database. Your implementation might vary depending on the customization made to the OHMPI object structure and to the scripts used to create the OHMPI database.
This chapter includes the following sections:
The OHMPI database stores information about the entities being indexed, such as people or businesses. The database stores records from local systems in their original form and also stores a record for each object that is considered to be the single best record (SBR).
The structure of the database tables that store object information is dependent on the information specified in the object.xml file created by the wizard. Oracle Healthcare Master Person Index generates a script to create the tables and fields in the database based on the information in object.xml. If you update object.xml, regenerating the application updates the database scripts accordingly. This allows you to define the database as you define the object structure.
While most of the structures created in the database are based on information in object.xml, some of the tables, such as sbyn_seq_table and sbyn_common_detail, are standard for all implementations. The database includes tables that store information about the objects defined for the OHMPI application as well as tables that store common maintenance information, transactional information, and external system information. The database includes the tables listed in Table 3-1.
Table 3-1 Oracle Healthcare Master Person Index Database Tables
| Table Name | Description |
SBYN_OBJECT_NAME |
Stores information for the parent objects associated with local system records. This database table is named by the parent object name. For example, a table storing company objects is named sbyn_company; a table storing person objects is named sbyn_person. Only one table stores parent object information for system records. |
SBYN_OBJECT_NAMESBR |
Stores information for the parent objects associated with single best records. This database table is named by the parent object name followed by SBR. For example, a table storing company objects is named sbyn_companysbr; a table storing person objects is named sbyn_personsbr. Only one table stores parent object information for SBRs. |
SBYN_CHILD_OBJECT |
Stores information for child objects associated with local system records. These database tables are named by their object name. For example, a table storing address objects is named sbyn_address; a table storing comment objects is named sbyn_comment. One database table is created for each child object defined in the object structure. |
SBYN_CHILD_OBJECTSBR |
Stores information for child objects associated with a single best record. These database tables are named by their object name followed by SBR. For example, a table storing address objects is named sbyn_addresssbr; a table storing comment objects is named sbyn_commentsbr. One SBR database table is created for each child object defined in the object structure. |
SBYN_APPL |
Lists the applications with which each item in stc_common_header is associated. Currently the only item in this table is MPI. |
SBYN_ASSUMEDMATCH |
Stores information about records that were automatically matched by the OHMPI application. |
SBYN_AUDIT |
Stores audit information about each time object information is accessed from the MIDM. Note: If audit logging is enabled, this table can grow very large and might require periodic archiving. |
SBYN_COMMON_DETAIL |
Contains all of the processing codes associated with the items listed in sbyn_common_header. |
SBYN_COMMON_HEADER |
Contains a list of the different types of processing codes used by the OHMPI application. These types are also associated with the drop-down lists you can specify for the MIDM. |
SBYN_ENTERPRISE |
Stores the local ID and system pairs, along with their associated EUID. |
SBYN_MERGE |
Stores information about all merge and unmerge transactions processed from either external systems or the MIDM. |
SBYN_OVERWRITE |
Stores information about fields that are locked for updates in an SBR. |
SBYN_POTENTIALDUPLICATES |
Stores a list of potential duplicate records and flags potential duplicate pairs that have been resolved. |
SBYN_SEQ_TABLE |
Stores the sequential codes that are used in other tables in the database, such as EUIDs, transaction numbers, and so on. |
SBYN_SYSTEMOBJECT |
Stores information about the system objects in the database, including the local ID and system, create date and user, status, and so on. |
SBYN_SYSTEMS |
Stores a list of systems in your organization, along with defining information. |
SBYN_SYSTEMSBR |
Stores transaction information about an SBR, such as the create or update date, status, and so on. |
SBYN_TRANSACTION |
Stores a history of changes to each record stored in the database. |
SBYN_USER_CODE |
Like the sbyn_common_detail table, this table stores processing codes and drop-down list values. This table contains additional validation information that allows you to validate information in a dependent field (for example, to validate cities against the entered postal code). |
The tables on the following pages describe each column in the default database tables.
This table stores the parent object in each system record received by the OHMPI application. It is linked to the tables that store each child object in the system record by the object_name id column (where object_name is the name of the parent object). This table contains the columns listed below regardless of the design of the object structure, and also contains a column for each field you defined for the parent object in object.xml. Columns to store standardized or phonetic versions of certain fields are automatically added when you specify certain match types in the wizard.
Table 3-2 lists Oracle data types.
Table 3-2 SBYN_OBJECT_NAME Table Description
| Column Name | Data Type | Column Description |
SYSTEMCODE |
VARCHAR2(20) |
The system code for the system record. |
LID |
VARCHAR2(25) |
A local identification code assigned by the specified system. |
OBJECT_NAMEID |
VARCHAR2(20) |
A unique ID for the parent object in a system record. This is named according to the parent object. For example, if the parent object is "Company", the name of this column is "companyid"; if the parent object is "Person", the name of this column is "personid". |
This table stores the parent object of the SBR for each enterprise object in the OHMPI database. It is linked to the tables that store each child object in the SBR by the object_name id column (where object_name is the name of the parent object). This table contains the columns listed below regardless of the design of the object structure, and also contains a column for each field defined for the parent object in object.xml. In addition, columns to store standardized or phonetic versions of certain fields are automatically added when you specify certain match types in the wizard.
Table 3-3 lists Oracle data types.
Table 3-3 SBYN_OBJECT_NAMESBR Table Description
EUID |
VARCHAR2(20) |
The enterprise unique identifier assigned by the OHMPI application. |
OBJECT_NAMEID |
VARCHAR2(20) |
The sbyn_child_object tables (where child_object is the name of a child object in the object structure) store information about the child objects associated with a system record in the OHMPI application. All tables storing child object information for system records contain the columns listed below. The remaining columns are defined by the fields you specify for each child object in the object structure definition file, including any standardized or phonetic fields.
Table 3-4 lists Oracle data types.
Table 3-4 SBYN_CHILD_OBJECT Table Description
OBJECT_NAMEID |
VARCHAR2(20) |
The unique ID for the parent object associated with the child object in the system record. |
CHILD_OBJECTID |
VARCHAR2(20) |
The unique ID for each record in the table. This column cannot be null. |
The sbyn_child_objects br tables (where child_object is the name of a child object in the object structure) store information about the child objects associated with an SBR in the OHMPI application. All tables storing child object information for SBRs contain the columns listed below. The remaining columns are defined by the fields you specify for each child object in object.xml, including any standardized or phonetic fields.
Table 3-5 lists Oracle data types.
Table 3-5 SBYN_CHILD_OBJECT and SBYN_CHILD_OBJECTSBR Table Description
OBJECT_NAMEID |
VARCHAR2(20) |
The unique ID for the parent object associated with the child object in the SBR. |
CHILD_OBJECTID |
VARCHAR2(20) |
This table stores information about the applications used in the Oracle Healthcare Master Person Index system. Currently, there is only one entry, MPI.
Table 3-6 lists Oracle data types.
Table 3-6 SBYN_APPL Table Description
| Column Name | Data Type | Description |
APPL_ID |
NUMBER(10) |
The unique sequence number code for the listed application. |
CODE |
VARCHAR2(8) |
A unique code for the application. |
DESCR |
VARCHAR2(30) |
A brief description of the application. |
READ_ONLY |
CHAR(1) |
An indicator of whether the current entry can be modified. If the value of this column is Y, the entry cannot be modified. |
CREATE_DATE |
DATE |
The date the application entry was created. |
CREATE_USERID |
VARCHAR2(20) |
The logon ID of the user who created the application entry. |
This table maintains a record of each assumed match transaction that occurs in the OHMPI application, allowing you to review these transactions and, if necessary, reverse an assumed match. This table can grow quite large over time. Oracle recommends that you archive the table periodically.
Table 3-7 lists Oracle data types.
Table 3-7 SBYN_ASSUMEDMATCH Table Description
ASSUMEDMATCHID |
VARCHAR2(20) |
The unique ID for the assumed match transaction. |
EUID |
VARCHAR2(20) |
The EUID into which the incoming record was merged. |
SYSTEMCODE |
VARCHAR2(20) |
The system code for the source system (that is, the system from which the incoming record originated). |
LID |
VARCHAR2(25) |
The local ID of the record in the source system. |
WEIGHT |
VARCHAR2(20) |
The matching weight between the incoming record and the EUID record into which it was merged. |
TRANSACTION NUMBER |
VARCHAR2(20) |
The transaction number associated with the assumed match. |
This table maintains a log of each instance in which any of the OHMPI database tables are accessed through the MIDM. This includes each time a record appears on a search results page, a comparison page, the Record Details page, and so on. This log is only maintained if the MIDM is configured for it. This table can grow very large over time and might require periodic archiving.
Table 3-8 lists Oracle data types.
Table 3-8 SBYN_AUDIT Table Description
AUDIT_ID |
VARCHAR2(20) |
The unique identification code for the audit record. This column cannot be null. |
PRIMARY_OBJECT_TYPE |
VARCHAR2(20) |
The name of the parent object as defined in object.xml. |
EUID |
VARCHAR2(15) |
The EUID whose information was accessed during an MIDM transaction. |
EUID_AUX |
VARCHAR2(15) |
The second EUID whose information was accessed during an MIDM transaction. A second EUID appears when viewing information about merge and unmerge transactions, comparisons, and so on. |
FUNCTION |
VARCHAR2(32) |
The type of transaction that caused the audit record to be written. This column cannot be null. |
DETAIL |
VARCHAR2(120) |
A brief description of the transaction that caused the audit record to be written. |
CREATE_DATE |
DATE |
The date the transaction that created the audit record was performed. This column cannot be null. |
CREATE_BY |
VARCHAR2(20) |
The user ID of the person who performed the transaction that caused the audit log. This column cannot be null. |
This table stores the processing codes and description for all of the common maintenance data elements. This is the detail table for sbyn_common_header. Each data element in sbyn_common_detail is associated with a data type in sbyn_common_header by the common_header_id column. None of the columns in this table can be null.
Table 3-9 lists Oracle data types.
Table 3-9 SBYN_COMMON_DETAIL Table Description
COMMON_DETAIL_ID |
NUMBER(10) |
The unique identification code of the common table data element. |
COMMON_HEADER_ID |
NUMBER(10) |
The unique identification code of the common table data type associated with the data element (as stored in the common_header_id column of the sbyn_common_header table). |
CODE |
VARCHAR2(20) |
The processing code for the common table data element. |
DESCR |
VARCHAR2(50) |
A description of the common table data element. |
READ_ONLY |
CHAR(1) |
An indicator of whether the common table data element can be modified. |
CREATE_DATE |
DATE |
The date the data element record was created. |
CREATE_USERID |
VARCHAR2(20) |
The user ID of the person who created the data element record. |
This table stores a description of each type of common maintenance data and is the header table for sbyn_common_detail. Together, these tables store the processing codes and drop-down menu descriptions for each common table data type. For a person index, common table data types might include Religion, Language, Marital Status, and so on. For a business index, common table data types might include Address Type, Phone Type, and so on. None of the columns in this table can be null.
Table 3-10 lists Oracle data types.
Table 3-10 SBYN_COMMON_HEADER Table Description
COMMON_HEADER_ID |
VARCHAR2(10) |
The unique identification code of the common table data type. |
APPL_ID |
VARCHAR2(10) |
The application ID from sbyn_appl that corresponds to the application for which the common table data type is used. |
CODE |
VARCHAR2(8) |
A unique processing code for the common table data type. |
DESCR |
VARCHAR2(50) |
A description of the common table data type. |
READ_ONLY |
CHAR(1) |
An indicator of whether an entry in the table is read-only (if this column is set to "Y", the entry is read-only). |
MAX_INPUT_LEN |
NUMBER(10) |
The maximum number of characters allowed in the code column for the common table data type. |
TYP_TABLE_CODE |
VARCHAR2(3) |
This column is not currently used. |
CREATE_DATE |
DATE |
The date the common table data type record was created. |
CREATE_USERID |
VARCHAR2(20) |
The user ID of the person who created the common table data type record. |
This table stores a list of all the system and local ID pairs assigned to the enterprise records in the database, along with the associated EUID for each pair. This table is linked to sbyn_systemobject by the system code and LID columns, and is linked to sbyn_systemsbr by the euid column. This table maintains links between the SBR and its associated system objects. None of the columns in this table can be null.
Table 3-11 lists Oracle data types.
Table 3-11 SBYN_ENTERPRISE Table Description
SYSTEMCODE |
VARCHAR2(20) |
The processing code of the system associated with the local ID. |
LID |
VARCHAR2(25) |
The local ID associated with the system and EUID. |
EUID |
VARCHAR2(20) |
The EUID associated with the local ID and system. |
This table maintains a record of each merge transaction that occurs in the OHMPI application, both through the MIDM and from external systems. It also records any unmerges that occur.
Table 3-12 lists Oracle data types.
Table 3-12 SBYN_MERGE Table Description
MERGE_ID |
VARCHAR2(20) |
The unique, sequential identification code of merge record. This column cannot be null. |
KEPT_EUID |
VARCHAR2(20) |
The EUID of the record that was retained after the merge transaction. This column cannot be null. |
MERGED_EUID |
VARCHAR2(20) |
The EUID of the record that was not retained after the merge transaction. |
MERGE_TRANSACTIONNUM |
VARCHAR2(20) |
The transaction number associated with the merge transaction. This column cannot be null. |
UNMERGE_TRANSACTIONNUM |
VARCHAR2(20) |
The transaction number associated with the unmerge transaction. |
This table stores information about the fields that are locked or linked for updates in the SBRs. It stores the EUID of the SBR, the ePath to the field, and the current locked value of the field or the system code and LID of the linked system object.
Table 3-13 lists Oracle data types.
Table 3-13 SBYN_OVERWRITE Table Description
EUID |
VARCHAR2(20) |
The EUID of an SBR containing fields for which the overwrite lock is set. |
PATH |
VARCHAR2(200) |
The ePath to a field that is locked in an SBR from the MIDM. |
TYPE |
VARCHAR2(20) |
The data type of a field that is locked in an SBR. |
INTEGERDATA |
NUMBER(38) |
The data that is locked for overwrite in an integer field. |
BOOLEANDATA |
NUMBER(38) |
The data that is locked for overwrite in a boolean field or the system code and LID of the linked system object. |
STRINGDATA |
VARCHAR2(200) |
The data that is locked for overwrite in a string field or the system code and LID of the linked system object. |
BYTEDATA |
CHAR(2) |
The data that is locked for overwrite in a byte field or the system code and LID of the linked system object. |
LONGDATA |
LONG |
The data that is locked for overwrite in a long integer field or the system code and LID of the linked system object. |
DATEDATA |
DATE |
The data that is locked for overwrite in a date field or the system code and LID of the linked system object. |
FLOATDATA |
NUMBER(38,4) |
The data that is locked for overwrite in a floating decimal field or the system code and LID of the linked system object. |
TIMESTAMPDATA |
DATE |
The data that is locked for overwrite in a timestamp field or the system code and LID of the linked system object. |
This table maintains a list of all records that are potential duplicates of one another. It also maintains a record of whether a potential duplicate pair has been resolved or permanently resolved.
Table 3-14 lists Oracle data types.
Table 3-14 SBYN_POTENTIALDUPLICATES Table Description
POTENTIALDUPLICATEID |
VARCHAR2(20) |
The unique identification number of the potential duplicate transaction. |
WEIGHT |
VARCHAR2(20) |
The matching weight of the potential duplicate pair. |
TYPE |
VARCHAR2(15) |
This column is reserved for future use. |
DESCRIPTION |
VARCHAR2(120) |
A description of what caused the potential duplicate flag. |
STATUS |
VARCHAR2(15) |
The status of the potential duplicate pair. The possible values are:
HIGHMATCHFLAG |
VARCHAR2(15) |
RESOLVEDUSER |
VARCHAR2(30) |
The user ID of the person who resolved the potential duplicate status. |
RESOLVEDDATE |
DATE |
The date the potential duplicate status was resolved. |
RESOLVEDCOMMENT |
VARCHAR2(120) |
Comments regarding the resolution of the duplicate status. This is not currently used. |
EUID2 |
VARCHAR2(20) |
The EUID of the second record in the potential duplicate pair. |
TRANSACTIONNUMBER |
VARCHAR2(20) |
The transaction number associated with the transaction that produced the potential duplicate flag. |
EUID1 |
VARCHAR2(20) |
The EUID of the first record in the potential duplicate pair. |
This table controls and maintains a record of the sequential identification numbers used in various tables in the database, ensuring that each number is unique and assigned in order. Several of the ID numbers maintained in this table are determined by the object structure. The numbers are assigned sequentially, but are cached in chunks of 1000 numbers for optimization (so the application does not need to query the sbyn_seq_table table for each transaction). The chunk size for the EUID sequence is configurable. If the Repository server is reset before all allocated numbers are used, the unused numbers are discarded and never used, and numbering is restarted at the beginning of the next 1000-number chunk.
Table 3-15 lists Oracle data types.
Table 3-15 SBYN_SEQ_TABLE Table Description
SEQ_NAME |
VARCHAR2(20) |
The name of the object for which the sequential ID is stored. |
SEQ_COUNT |
NUMBER(38) |
The current value of the sequence. The next record will be assigned the current value plus one. |
The default sequence numbers are listed in the following table.
Table 3-16 Default Sequence Numbers
| Sequence Name | Description |
EUID |
The sequence number that determines how EUIDs are assigned to new records. The chunk size for the EUID sequence number is configurable in the |
POTENTIALDUPLICATE |
The sequence number assigned each potential duplicate transaction record in sbyn_potentialduplicates (column name "potentialduplicateid"). |
TRANSACTIONNUMBER |
The sequence number assigned to each transaction in the OHMPI application. This number is stored in sbyn_transaction (column name "transactionnumber"). |
ASSUMEDMATCH |
The sequence number assigned to each assumed match transaction record in sbyn_assumedmatch (column name "assumedmatchid"). |
AUDIT |
The sequence number assigned to each audit log record in sbyn_audit (column name "audit_id"). |
MERGE |
The sequence number assigned to each merge transaction in sbyn_merge (column name "merge_id"). |
SBYN_APPL |
The sequence number assigned to each application listed in sbyn_appl (column name "appl_id"). |
The sequence number assigned to each common table data type listed in sbyn_common_header (column name "common_header_id"). |
The sequence number assigned to each common table data element listed in sbyn_common_detail (column name "common_detail_id"). |
OBJECT_NAME |
Each parent and child object system record table is assigned a sequential ID. The column names are named after the object (for example, sbyn_address has a sequential column named "addressid"). The parent object ID is included in each child object table. |
OBJECT_NAMESBR |
Each parent and child object SBR table is assigned a sequential ID. The column names are named after the object (for example, sbyn_addresssbr has a sequential column named "addressid"). The parent object ID is included in each child object SBR table. |
This table stores information about the system records in the database, including their local ID and source system pairs. It also stores transactional information, such as the create or update date and function.
Table 3-17 lists Oracle data types.
Table 3-17 SBYN_SYSTEMOBJECT Table Description
SYSTEMCODE |
VARCHAR2(20) |
The processing code of the system associated with the local ID. This column cannot be null. |
LID |
VARCHAR2(25) |
The local ID associated with the system and EUID (the associated EUID is found in sbyn_enterprise). This column cannot be null. |
CHILDTYPE |
VARCHAR2(20) |
The type of object being processed (currently only the name of the parent object). This column is reserved for future use. |
CREATEUSER |
VARCHAR2(30) |
The user ID of the person who created the system record. |
CREATEFUNCTION |
VARCHAR2(20) |
The type of transaction that created the system record. |
CREATEDATE |
DATE |
The date the system record was created. |
UPDATEUSER |
VARCHAR2(30) |
The user ID of the person who last updated the system record. |
UPDATEFUNCTION |
VARCHAR2(20) |
The type of transaction that last updated the system record. |
UPDATEDATE |
DATE |
The date the system record was last updated. |
STATUS |
VARCHAR2(15) |
The status of the system record. The status can be one of these values:
This table stores information about each system integrated into the Oracle Healthcare Master Person Index environment, including the system's processing code and name, a brief description, the format of the local IDs, and whether any of the system information should be masked.
Table 3-18 lists Oracle data types.
Table 3-18 SBYN_SYSTEMS Table Description
SYSTEMCODE |
VARCHAR2(20) |
The unique processing code of the system. |
DESCRIPTION |
VARCHAR2(120) |
A brief description of the system, or the system name. This is the value that appears in the tree view panes of the MIDM for each system and local ID pair. |
STATUS |
CHAR(1) |
The status of the system in the OHMPI application. A indicates active and D indicates deactivated. |
ID_LENGTH |
NUMBER |
The length of the local identifiers assigned by the system. This length does not include any additional characters added by the input mask. |
FORMAT |
VARCHAR2(60) |
The required data pattern for the local IDs assigned by the system. For more information about possible values and using Java patterns, see "Patterns" in the class list for |
INPUT_MASK |
VARCHAR2(60) |
A mask used by the MIDM to add punctuation to the local ID. For example, the input mask DD-DDD-DDD inserts a hyphen after the second and fifth characters in an 8-digit ID. These character types can be used.
VALUE_MASK |
VARCHAR2(60) |
A mask used to strip any extra characters that were added by the input mask for database storage. The value mask is the same as the input mask, but with an "x" in place of each punctuation mark. Using the input mask described above, the value mask is DDxDDDxDDD. This strips the hyphens before storing the ID. |
CREATE_DATE |
DATE |
The date the system information was inserted into the database. |
CREATE_USERID |
VARCHAR2(20) |
The logon ID of the user who inserted the system information into the database. |
UPDATE_DATE |
DATE |
The most recent date the system's information was updated. |
UPDATE_USERID |
VARCHAR2(20) |
The logon ID of the user who last updated the system's information. |
This table stores transactional information about the system records for the SBR, such as the create or update date and function. The sbyn_systemsbr table is indirectly linked to the sbyn_systemobjects table through sbyn_enterprise.
Table 3-19 lists Oracle data types.
Table 3-19 SBYN_SYSTEMSBR Table Description
EUID |
VARCHAR2(20) |
The EUID associated with system record (the associated system and local ID are found in sbyn_enterprise). This column cannot be null. |
CHILDTYPE |
VARCHAR2(20) |
CREATESYSTEM |
VARCHAR2(20) |
The system in which the system record was created. |
CREATEUSER |
VARCHAR2(30) |
CREATEFUNCTION |
VARCHAR2(20) |
CREATEDATE |
DATE |
The date the system object was created. |
UPDATEUSER |
VARCHAR2(30) |
UPDATEFUNCTION |
VARCHAR2(20) |
UPDATEDATE |
DATE |
The date the system object was last updated. |
STATUS |
VARCHAR2(15) |
The status of the enterprise record. The status can be one of these values:
REVISIONNUMBER |
NUMBER(38) |
The revision number of the SBR. This is used for version control. |
This table stores a history of changes made to each record in the OHMPI application, allowing you to view a transaction history and to undo certain actions, such as merging two object profiles.
Table 3-20 lists Oracle data types.
Table 3-20 SBYN_TRANSACTION Table Description
TRANSACTIONNUMBER |
VARCHAR2(20) |
The unique number of the transaction. |
LID1 |
VARCHAR2(25) |
LID2 |
VARCHAR2(25) |
The local ID of the second system record involved in the transaction. |
EUID1 |
VARCHAR2(20) |
EUID2 |
VARCHAR2(20) |
The EUID of the second object profile involved in the transaction. |
FUNCTION |
VARCHAR2(20) |
The type of transaction that occurred, such as update, add, merge, and so on. |
SYSTEMUSER |
VARCHAR2(30) |
The logon ID of the user who performed the transaction. |
TIMESTAMP |
TIMESTAMP |
The date and time the transaction occurred. |
DELTA |
BLOB |
A list of the changes that occurred to system records as a result of the transaction. |
SYSTEMCODE |
VARCHAR2(20) |
The processing code of the source system in which the transaction originated. |
LID |
VARCHAR2(25) |
The local ID of the system record involved in the transaction. |
EUID |
VARCHAR2(20) |
The EUID of the enterprise record involved in the transaction. |
This table is similar to the sbyn_common_header and sbyn_common_detail tables in that it stores processing codes and drop-down list values. This table is used when the value of one field is dependent on the value of another. For example, if you store credit card information, you could list each credit card type and specify a required format for the credit card number field. The data stored in this table includes the processing code, a brief description, and the format of the dependent fields.
Table 3-21 lists Oracle data types.
Table 3-21 SBYN_USER_CODE Table Description
CODE_LIST |
VARCHAR2(20) |
The code list name of the user code type (using the credit card example above, this might be similar to "CREDCARD"). This column links the values for each list. |
CODE |
VARCHAR2(20) |
The processing code of each user code element. |
DESCRIPTION |
VARCHAR2(50) |
A brief description or name for the user code. This is the value that appears in the drop-down list. |
FORMAT |
VARCHAR2(60) |
The required data pattern for the field that is constrained by the user code. For more information about possible values and using Java patterns, see "Patterns" in the class list for |
INPUT_MASK |
VARCHAR2(60) |
A mask used by the MIDM to add punctuation to the constrained field. For example, the input mask DD-DDD-DDD inserts a hyphen after the second and fifth characters in an 8-digit ID. These character types can be used.
VALUE_MASK |
VARCHAR2(60) |
The diagrams on the following pages illustrate the table structure and relationships for a sample Oracle Healthcare Master Person Index Oracle database designed for storing information about companies. The diagrams display attributes for each database column, such as the field name, data type, whether the field can be null, and primary keys. They also show directional relationships between tables and the keys by which the tables are related.
Figure 3-1 Sample Database Model (along with the following two diagrams
Figure 3-2 Sample Database Model (along with the previous and following diagrams)
Figure 3-3 Sample Database Model (along with the previous two diagrams)
