| Oracle® Healthcare Master Person Index Message Processing Reference Release 4.0 E68421-01 |
![]() Previous |
![]() Next |
This chapter provides an overview of the Java API for an Oracle Healthcare Master Person Index (OHMPI) application. For detailed information about the JAVA API classes and methods, refer to the Oracle Healthcare Master Person Index Javadocs. Unless otherwise noted, all classes and methods described in this chapter are public. Methods inherited from classes other than those described in this chapter are listed, but not described:
This chapter includes the following sections:
Oracle Healthcare Master Person Index provides several Java classes and methods to use to transform and process data in a Master Person Index or IHE Profile project. The master person index API is specifically designed to help you maintain the integrity of the data in the database by providing specific methods for updating, adding, and merging records in the database.
Oracle Healthcare Master Person Index provides a set of JAVA API classes that can be used with any object structure for the OHMPI application.
JAVA API classes provide the methods you need to perform basic data cleansing and processing functions against incoming data, such as performing searches, reviewing potential duplicates, adding and updating records, and merging and unmerging records. The primary class containing these functions is the MasterController class, which includes the executeMatch methods. Several classes support the MasterController class by defining additional objects and functions. Documentation for the JAVA API classes' methods is provided in Javadoc format.
Description
This method changes the status of a deactivated enterprise object back to active.
Syntax
public void activateEnterpriseObject(java.lang.String euid)
Parameters
| Name | Description |
| euid | The EUID associated with the enterprise object to activate. |
Returns
None
Throws
ProcessingException
UserException
Description
This method changes the status of a deactivated system object back to active.
Syntax
public void activateSystemObject(SystemObjectPK systemKey)
Parameters
| systemKey | The system code and local ID of the system object to activate. |
Returns
None
Throws
ProcessingException
UserException
Description
This method adds the system object to the enterprise object associated with the specified EUID.
Syntax
public void addSystemObject(java.lang.String euid, SystemObject sysobj)
Parameters
| euid | The EUID of the enterprise object to which you want to add the system object. |
| sysobj | The system object to add to the enterprise object. |
Returns
None
Throws
ProcessingException
UserException
Description
This method calculates potential duplicates for the specified EUID and transaction ID.
Syntax
public void calculatePotentialDuplicates(java.lang.String euid, java.lang.String transID)
Parameters
| euid | The EUID for which potential duplicates are calculated. |
| transID | The transaction number for which potential duplicates are calculated. |
Returns
None
Throws
ProcessingException
Description
This method calculates a new single best record (SBR) for an enterprise object that is updated.
Syntax
public SBR calculateSBR(EnterpriseObject eo)
Parameters
| eo | The enterprise object whose SBR is recalculated. |
Returns
Recalculated SBR of the enterprise object.
Throws
ProcessingException
UserException
Description
This method counts the number of assumed match records matching the date criteria specified in search object.
Syntax
public int countAssumedMatches(AssumedMatchSearchObject amso)
Parameters
None
Returns
Count of the assumed match records matching the search criteria.
Throws
ProcessingException
UserException
Description
This method counts the number of potential duplicate records matching the criteria specified in search object.
Syntax
public int countPotentialDuplicates(PotentialDuplicateSearchObject pdso)
Parameters
None
Returns
Count of the potential duplicate records matching the search criteria.
Throws
ProcessingException
UserException
Description
This method creates a new enterprise object to add to the master index database using the information in the specified system object.
Syntax
public EnterpriseObject createEnterpriseObject(SystemObject sysobj)
Parameters
| sysobj | The system object to use as a basis for the enterprise object. |
Returns
The enterprise object created from the specified system object.
Throws
ProcessingException
UserException
Description
This method changes the status of an enterprise object from active to inactive and deletes all potential duplicate listings for that object.
Syntax
public void deactivateEnterpriseObject(java.lang.String euid)
Parameters
| euid | The EUID associated with the enterprise object to deactivate. |
Returns
None
Throws
ProcessingException
UserException
Description
This method changes the status of an active system object to inactive.
Syntax
public void deactivateSystemObject(SystemObjectPK systemKey)
Parameters
| systemKey | The system code and local ID of the system object to deactivate. |
Returns
None
Throws
ProcessingException
UserException
Description
This method permanently deletes a system object from its associated enterprise object.
Syntax
public void deleteSystemObject(SystemObjectPK systemKey)
Parameters
| systemKey | The system code and local ID of the system object to delete. |
Returns
None
Throws
ProcessingException
UserException
executeMatch is one of four methods that process a system object based on the configuration defined for the Master Index Manager Service and associated runtime components. This method searches for possible matches in the database, and if it finds a match, it replaces the system object (instead of updating the system object, which is what executeMatchUpdate does).
The following runtime components configure executeMatch.
The Query Builder defines the blocking queries used for matching.
Threshold configuration specifies which blocking query to use and specifies matching parameters, including duplicate and match thresholds and whether potential duplicates are automatically recalculated for updated records.
The pass controller and block picker classes specify how the blocking query is executed.
Syntax
public MatchResult executeMatch(SystemObject sysObj)
Parameters
| sysObj | The system object to process into the database. |
Returns
A match result object containing the results of the matching process.
Throws
ProcessingException
UserException
executeMatchDupRecalc is one of four methods that process a system object based on the configuration defined for the Master Index Manager Service and associated runtime components. It is configured by the same components as executeMatch, and is similar to executeMatch but allows you to control whether potential duplicates are recalculated when an object is updated regardless of whether the update mode is set to optimistic or pessimistic.
executeMatchDupRecalc differs from executeMatch in two ways:
It provides an override flag for the update mode specified in the Threshold configuration file.
The match result object returned by this method includes an indicator of whether match fields were modified. This helps you determine whether you need to process potential duplicates for this object at a later time.
Note: To process potential duplicates at a later time, callcalculatePotentialDuplicates. |
Syntax
public MatchResult executeMatchDupRecalc(SystemObject sysObj, java.lang.Boolean performPessimistic)
Parameters
| performPessimistic | A Boolean indicator of whether to recalculate potential duplicates on update or to defer it until later. Specify true to recalculate on update and false to defer the recalculation. |
Returns
Throws
ProcessingException
UserException
executeMatchGui is identical to executeMatch, but it is only called by the Enterprise Data Manager. It processes a system object based on the configuration defined for the Master Index Manager Service and associated runtime components. This method searches for possible matches in the database, and if it finds a match, it replaces the system object (instead of updating the system object).
The following runtime components configure executeMatchGui:
Threshold configuration specifies which blocking query to use and specifies matching parameters, including duplicate and match thresholds.
Syntax
public MatchResult executeMatchGui(SystemObject sysObj)
Parameters
Returns
Throws
ProcessingException
UserException
executeMatchUpdate is one of four methods that process a system object based on the configuration defined for the Master Index Manager Service and associated runtime components. It is configured by the same components as executeMatch. This method searches for possible matches in the database, and if it finds a match, it updates the system object (instead of replacing the system object, which is what executeMatch does).
The following runtime components configure executeMatchUpdate.
Syntax
public MatchResult executeMatchUpdate(SystemObject sysObj)
Parameters
Returns
Throws
ProcessingException
UserException
Description
executeMatchUpdateDupRecalc is one of four methods that process a system object based on the configuration defined for the Master Index Manager Service and associated runtime components. It is configured by the same components as executeMatch, and is similar to executeMatchUpdate but allows you to control whether potential duplicates are recalculated when an object is updated regardless of whether the update mode is set to optimistic or pessimistic.
executeMatchUpdateDupRecalc differs from executeMatchUpdate in two ways:
Syntax
public MatchResult executeMatchUpdateDupRecalc(SystemObject sysObj, java.lang.Boolean performPessimistic)
Parameters
Returns
Throws
ProcessingException
UserException
Description
This method retrieves the Assumed Match threshold.
Syntax
public float getAssumedMatchThreshold()
Description
This method retrieves the configuration for a master controller parameter, such as the EUID length, duplicate threshold, or match threshold.
Syntax
public java.lang.Object getConfigurationValue(java.lang.String param)
Parameters
| param | This parameter is defined in the Threshold configuration file of the Master Index Project. |
Returns
An object containing the value of the specified parameter.
Throws
ProcessingException
UserException
Description
This method retrieves the status of the master index database.
Syntax
public java.lang.String getDatabaseStatus()
Parameters
None
Returns
The status of the master index database.
Throws
ProcessingException
UserException
Description
This method retrieves the potential duplicate threshold.
Syntax
public float getDuplicateThreshold()
Description
This method returns the enterprise object associated with the specified EUID.
Syntax
public EnterpriseObject getEnterpriseObject(java.lang.String euid)
Parameters
| euid | The EUID of the enterprise object you want to retrieve. |
| options | A list of ePaths that define which types of objects to retrieve to create the resulting EnterpriseObject. |
| key | The system object primary key. |
Returns
The enterprise object associated with the specified EUID. Returns null if no enterprise object with the specified EUID is found.
Throws
ProcessingException
UserException
Description
This method returns the EUID associated with the system code and local ID specified in the SystemObjectPK object.
Syntax
public java.lang.String getEUID(SystemObjectPK key)
Parameters
| key | The system object key containing the system code and local ID to use as search criteria. |
Returns
The EUID associated with the given system object key. Returns null if no results are found.
Throws
ProcessingException
UserException
Description
This method returns a map with (fieldName, actual value for link) for the given EO.
Syntax
public java.util.Map getLinkValues(EnterpriseObject eo)
Parameters
| eo | The EnterpriseObject that has LINKs. |
Returns
resultMap map (fieldName, actual value for link) for the given EO.
Throws
ObjectException
ConnectionInvalidException
OPSException
ProcessingException
Description
This method retrieves the history of the merge transactions associated with the specified EUID.
Syntax
public MergeHistoryNode getMergeHistory(java.lang.String euid)
Parameters
| euid | The EUID associated with the merge history to retrieve. |
Returns
The merge history tree for the specified EUID.
Throws
ProcessingException
UserException
Description
This method retrieves the SBR revision number for the specified EUID.
Syntax
public java.lang.Integer getRevisionNumber(java.lang.String euid)
Parameters
| euid | The EUID containing the SBR revision number to retrieve. |
Returns
The revision number for the SBR.
Throws
ProcessingException
Description
This method returns the single best record (SBR) object associated with the specified EUID.
Syntax
public SBR getSBR(java.lang.String euid)
Parameters
| euid | The EUID of the enterprise object whose SBR you want to retrieve. |
Returns
The SBR object associated with the specified EUID. Returns null if no SBR associated with the specified EUID is found.
Throws
ProcessingException
UserException
Description
This method returns the system object associated with the system code and local ID contained in the specified SystemObjectPK object.
Syntax
public SystemObject getSystemObject(SystemObjectPK key)
Parameters
| key | The system object key containing the local ID and system code to lookup. |
Returns
The system object associated with the specified local ID and system code.
Throws
ProcessingException
UserException
Description
This method inserts an audit log record of a transaction into the database.
Syntax
public void insertAuditLog(AuditDataObject auditObject)
Parameters
| auditObject | The audit log record to insert. |
Returns
None
Throws
ProcessingException
UserException
Description
This method returns an iterator of AssumedMatchSummary objects based on the criteria contained in the assumed match search object (AssumedMatchSearchObject class).
Syntax
public AssumedMatchIterator lookupAssumedMatches(AssumedMatchSearchObject obj)
Parameters
| obj | An instance of AssumedMatchSearchObject containing the potential duplicate search criteria. |
Returns
An iterator of search results (AssumedMatchSummary objects).
Throws
ProcessingException
UserException
Description
This method looks up an audit log record based on the criteria contained in an audit search object.
Syntax
public AuditIterator lookupAuditLog(AuditSearchObject obj)
Parameters
| obj | An instance of AuditSearchObject containing the audit log search criteria. |
Returns
An iterator of audit log matches to the given search criteria.
Throws
ProcessingException
UserException
Description
This method returns an iterator of PotentialDuplicateSummary objects based on the criteria contained in the potential duplicate search object (PotentialDuplicateSearchObject class).
Syntax
public PotentialDuplicateIterator lookupPotentialDuplicates(PotentialDuplicateSearchObject obj)
Parameters
| obj | An instance of PotentialDuplicateSearchObject containing the potential duplicate search criteria. |
Returns
An iterator of search results (PotentialDuplicateSummary objects).
Throws
ProcessingException
UserException
Description
This method retrieves the attributes of an external system from the master index database based on the system code.
Syntax
public SystemDefinition lookupSystemDefinition(java.lang.String systemCode)
Parameters
| systemCode | The system code of an external system. |
Returns
A set of system attributes for the system identified the given system code.
Throws
ProcessingException
Description
This method retrieves the attributes of an external system from the master index database, such as the system code, masking flags, local ID format and so on.
Syntax
public SystemDefinition[] lookupSystemDefinitions()
Parameters
None
Returns
An array of system attributes.
Throws
ProcessingException
Description
This method returns an array of all system objects associated with the specified EUID.
Syntax
public SystemObjectPK[] lookupSystemObjectPKs(java.lang.String euid)
Parameters
| euid | The EUID of the enterprise object containing the system objects to retrieve. |
Returns
An array of system objects associated with the specified EUID.
Throws
ProcessingException
UserException
Description
This method looks up the active system objects associated with the specified EUID.
Syntax
public SystemObject[] lookupSystemObjects(java.lang.String euid)
Parameters
| euid | The EUID whose associated system objects will be retrieved. |
Returns
An array of system objects that are associated with the specified EUID.
Throws
ProcessingException
UserException
Description
This method returns a transaction summary for the transaction associated with the specified transaction number.
Syntax
public TransactionSummary lookupTransaction(java.lang.String transId)
Parameters
| transId | The transaction number for the transaction to look up. |
Returns
The transaction summary for the specified transaction ID.
Throws
ProcessingException
UserException
Description
This method returns an array of transaction summaries based on the search criteria contained in the specified transaction search object.
Syntax
public TransactionIterator lookupTransactions(TransactionSearchObject obj)
Parameters
| obj | The transaction search object containing the search criteria. |
Returns
An array of transaction summaries matching the given search criteria.
Throws
ProcessingException
UserException
Description
This method merges two enterprise objects based on the specified EUID and enterprise object.
Syntax
public MergeResult mergeEnterpriseObject(java.lang.String sourceEUID, EnterpriseObject destinationEO, boolean calculateOnly)
Parameters
| sourceEUID | The EUID of the enterprise object that will not survive the merge. |
| destinationEO | The EUID of the enterprise object that will survive the merge. |
| calculateOnly | An indicator of whether to commit changes to the database or to simply compute the merge results. Specify false to commit the changes. |
Returns
The results of the merge operation.
Throws
ProcessingException
UserException
Description
This method merges multiple enterprise objects based on the specified EUIDs and enterprise object.
Syntax
public MergeResult[] mergeMultipleEnterpriseObjects(java.lang.String[] sourceEUIDs, EnterpriseObject destinationEO, java.lang.String[] srcRevisionNumbers, java.lang.String destRevisionNumber, boolean calculateOnly)
Parameters
| srcRevisionNumbers | The SBR revision number of the non-surviving enterprise object. |
| destRevisionNumber | The SBR revision number of the surviving enterprise object. |
Returns
Throws
ProcessingException
UserException
Description
Merges two system objects from the specified system. The system objects may belong to a single enterprise object or to two different enterprise objects.
Syntax
public MergeResult mergeSystemObject(java.lang.String systemCode, java.lang.String sourceLID, java.lang.String destLID, boolean calculateOnly)
Parameters
| systemCode | The processing code of the system to which the two system objects belong. |
| sourceLID | The local ID of the system object that will not survive the merge. |
| destLID | The local ID of the system object that will survive the merge. |
Returns
Throws
ProcessingException
UserException
Description
This method previews the undo assumed match.
Syntax
public EnterpriseObject previewUndoAssumedMatch(java.lang.String assumedMatchId)
Parameters
| assumedMatchId | Id of assumed match to be resolved |
Returns
EUID of new EO
Throws
ProcessingException
UserException
Description
This method flags a potential duplicate pair with Resolved or Auto Resolved status. If resolved, the pair can be marked as potential duplicates again during a future transaction. If auto-resolved, the pair is permanently flagged as resolved.
Syntax
public void resolvePotentialDuplicate(java.lang.String id, boolean autoResolve)
Parameters
| id | The potential duplicate ID of the pair to be resolved. |
| autoResolve | A Boolean value indicating whether to resolve or auto-resolve the pair. Use true for auto-resolve and false for resolve. |
Returns
None
Throws
ProcessingException
UserException
Description
This method returns an iterator of enterprise objects that match the specified search criteria and options.
Syntax
public EOSearchResultIterator searchEnterpriseObject(EOSearchCriteria criteria, EOSearchOptions searchOptions)
Parameters
| criteria | An EOSearchCriteria object containing the search criteria. |
| searchOptions | An EOSearchOptions object defining attributes of the search. |
Returns
An iterator containing the results of the query.
Throws
ProcessingException
UserException
Description
This method transfers a system object from one enterprise record to another enterprise record.
Syntax
public void transferSystemObject(java.lang.String toEUID, SystemObjectPK systemKey)
Parameters
| toEUID | The EUID of the enterprise object to which the system object will be transferred. |
| systemKey | The system code and local ID of the system object to transfer. |
Returns
None
Throws
ProcessingException
UserException
Description
This method reverses an assumed match transaction, unmerging the two objects that were matched and creating a new enterprise object for the record that caused the assumed match. Potential duplicates are calculated for the new enterprise object.
Syntax
public java.lang.String undoAssumedMatch(java.lang.String assumedMatchId)
Parameters
| assumedMatchId | The ID of the assumed match transaction to reverse. |
Returns
The EUID of the newly created enterprise object resulting from the reversing assumed match.
Throws
ProcessingException
UserException
Description
This method unmerges the two enterprise objects that were involved in the most recent merge transaction for the specified EUID. When the calculateOnly is set to true, the unmerge results is calculated, but the changes are not committed to the database.
Syntax
public MergeResult unmergeEnterpriseObject(java.lang.String euid, boolean calculateOnly)
Parameters
| euid | The EUID of the enterprise object to be unmerged. |
| calculateOnly | An indicator of whether to commit the unmerge to the database or to calculate the changes for viewing. Specify true to calculate for viewing and false to commit to the database. |
Returns
The result of the unmerge transaction.
Throws
ProcessingException
UserException
Description
This method unmerges the two system objects that were involved in the most recent merge transaction for the specified local ID. When the calculateOnly is set to true, the unmerge results is computed, but the changes are not committed to the database.
Syntax
public MergeResult unmergeSystemObject(java.lang.String systemCode, java.lang.String sourceLID, java.lang.String destLID, boolean calculateOnly)
Parameters
| systemCode | The system code of the system object to be unmerged. |
| sourceLID | The local ID of the non-surviving system object. |
| destLID | The local ID of the surviving system object. |
| calculateOnly | An indicator of whether to commit unmerge to the database or to calculate the changes for viewing. Specify true to calculate for viewing; specify false to commit to the database. |
Returns
Throws
ProcessingException
UserException
Description
This method changes the status of a resolved or auto-resolved potential duplicate record pair back to unresolved and places the records back in the potential duplicate listing.
Syntax
public void unresolvePotentialDuplicate(java.lang.String id)
Parameters
| id | The potential duplicate ID of the records to be unresolved. |
Returns
None
Throws
ProcessingException
UserException
Description
This method updates the database to reflect the new values of the specified enterprise object. This method is similar to updateEnterpriseObject but it allows you to control whether potential duplicate recalculation is performed when an enterprise object is updated, regardless of whether the update mode is set to optimistic or pessimistic.
This method differs from updateEnterpriseObject in two ways:
The update result object returned by this method includes an indicator of whether match fields were modified. This helps you determine whether you need to process potential duplicates for this object at a later time.
Syntax
public UpdateResult updateEnterpriseDupRecalc(EnterpriseObject eo, java.lang.Boolean performPessimistic)
Parameters
| eo | The enterprise object (EnterpriseObject class) to be updated. |
| performPessimistic | A Boolean indicator of whether to defer potential duplicate processing. Specify true to recalculate potential duplicates on update and false to defer recalculation to a later time. |
Returns
The UpdateResult object created from the update.
Throws
ProcessingException
UserException
Description
This method updates the database to reflect the new values of the specified enterprise object. If the enterprise object is deactivated during the update, potential duplicates are deleted for that object. If the enterprise object is still active, was changed during the transaction, and the update mode is set to pessimistic, the application checks whether any key fields were updated in the SBR of the enterprise object. If key fields were updated, potential duplicates are recalculated.
Syntax
public void updateEnterpriseObject(EnterpriseObject eo)
Parameters
Returns
None
Throws
ProcessingException
UserException
Description
This method updates SBR by collecting the values from MAP to the SBR that specified by EUID.
Syntax
public EnterpriseObject updateSBR(java.util.Map mapSystems, EnterpriseObject eo, boolean removalFlag)
Parameters
| mapSystems | The Map consists of epath as key and System as value from which the field should take for updating SBR. |
Returns
None
Throws
ProcessingException
UserException
