You run the kollacli command on the master node
and use it to configure and deploy OpenStack services to the
target nodes. To run kollacli commands, you
must be a member of the kolla group.
The kollacli command has a set of subcommands, which are organized by the objects that they manage.
To configure the layout of your OpenStack deployment, you perform actions on groups, hosts and services, as follows:
The kollacli group commands manage the associations between target nodes and the OpenStack services they run. Target nodes in the same group run the same services.
Example command: kollacli group addhost adds a host to a group.
The kollacli host commands manage the target nodes in a deployment.
Example command: kollacli host add adds a host to the list of target nodes.
The kollacli service commands manage the OpenStack services.
Example command: kollacli service addgroup adds a service to a group.
To configure your OpenStack deployment, you configure values for passwords and properties, as follows:
The kollacli password commands manage the passwords for the OpenStack components.
Example command: kollacli password set sets a value for a password.
The kollacli property commands manage the configuration settings for OpenStack services.
Example command: kollacli property set sets a value for a configuration property.
Once you have configured your deployment, you deploy OpenStack services with the kollacli deploy command.
Help on how to use the kollacli command is available, as follows:
To list all kollacli commands, use the kollacli help command.
To list the related commands for an object, use the kollacli help
objectfor example kollacli help host.To get help for a specific command, use the kollacli help
subcommandcommand, wheresubcommandis the name of the command, for example kollacli host list or kollacli service listgroups.
For a complete syntax reference for kollacli commands, see Appendix A, kollacli Command-Line Reference.
You can enable Bash command completion for the kollacli command, as follows:
Install the
bash-completionpackage, if it is not already installed:# yum install bash-completion
Use the kollacli complete command to generate the command completion function.
To display the function so you can copy and paste it into a file:
$ kollacli complete
To output the function to a file:
$ kollacli complete >/etc/bash_completion.d/kollacli
You need
rootprivileges to write to the/etc/bash_completion.ddirectory.Source the file to enable command completion:
$ source /etc/bash_completion.d/kollacli
The kollacli shell enables you to enter
several commands without having to type the
kollacli command each time. You start the
shell with the kollacli command. When you are
in the kollacli shell, the prompt changes to
(kollacli). From the shell prompt you can
enter kollacli commands in their short form,
for example:
$kollacli(kollacli)host list(kollacli)group listhosts
In addition to the help command, the
kollacli shell also supports the
-h and --help options for
obtaining help with kollacli commands.
To exit the kollacli shell and return to the operating system prompt, type exit, quit, or q.
When you use kollacli commands, such as the
kollacli property list command, to show what
you have configured, these commands have a
--format option which enable you to format the
output to suit your needs, as shown in the following table.
Option | Format |
| Comma-separated values.
Use the
The default is |
HTML |
| JavaScript Object Notation. |
| Simple ASCII display table. This is the default output format.
Use the |
| Space separated values with no headers. This format may be useful to pipe output to an operating system command. |
| YAML format. |
You can also use the --column option to select
the columns that are included in the output. Use multiple
--column options to select each column you
want. The names of the columns change depending on the
kollacli command used and the names are case
sensitive. By default, all columns are included.
