| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
This section explains the following:
To undeploy plug-ins from the OMS, follow the steps:
To undeploy a plug-in in EM CLI, use the following command:
$emcli undeploy_plugin_from_server
-plugin="plug-inId"
[-sys_password="sys_password"]
When a metadata plug-in is undeployed/redeployed, it is recomended that you run the following command. The command should be run in each OMS environment instance.
$emcli metric_control -command=flush_metadata_cache
If you want to undeploy only the plug-ins from the OMS, and not the entire Enterprise Manager system, then use the Plug-ins page within the Enterprise Manager Cloud Control Console. Do NOT use runInstaller to undeploy only the plug-ins.
To undeploy plug-ins from the Management Agent, follow the steps below:
These steps are applicable for obsolete and deprecated plug-ins as well.
Undeploying a plug-in from Management Agent removes all the targets that were monitored by the plug-in.
Undeployment of a plug-in from the Management Agent restarts the Management Agent. The Management Agent does not monitor any target during downtime.
To undeploy a plug-in using EM CLI, use the following command:
$emcli undeploy_plugin_from_agent
-plugin="pluginId"
{-agent_names="agent1[;agent2...]" | -all_discovery_only_agents}
To undeploy all versions of oracle.sysman.db2 plug-ins from all Management Agents where only Discovery Plug-ins are deployed, use the following command:
$emcli undeploy_plugin_from_agent -plugin=oracle.sysman.db2 -all_discovery_only_agents
