| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The patching methodology discussed in this chapter can only be used with Enterprise Manager Cloud Control Release 13.2.0.0.0 and later.
OMSPatcher automates the patching process by generating custom patching instructions based your particular environment and then automatically applies the patch.
This chapter covers the following topics:
With OMSPatcher, you can automatically patch a typical OMS configuration (core, plug-in homes) with minimal intervention.
OMSPatcher performs many of the pre-patch checks such as:
Configuration-based prerequisite checks
Patch-based binary prerequisite checks
OMSPatcher performs end-to-end configuration patching. Configuration patching is the process of patching a target based on its configuration. By incorporating the configuration information into the patch process, OMSPatcher is able to simplify patching tasks by automating most of the steps.
Single OMS – OMS application that runs from a single OMS instance of the system. OMSPatcher performs patching and deployment operations
Multiple OMS – OMS applications that run on two or more machines. The OMSs are connected by the Oracle WebLogic domain and separate managed servers. There is a one-to-one mapping between the managed servers and the separate OMS bits residing on a single machine. OMSPatcher provides auto-generated bash scripts (one per OMS instance) for UNIX based systems. For Windows, it only provides context-sensitive steps (text and HTML). For both cases, administrator needs to follow the steps given by OMSPatcher.
Single Instance Database or Real Application Cluster - shared or Real Application Cluster (RAC)
Example: Multi-OMS System
The following figure illustrates a multi-OMS deployment. The following terms are used:
Administrator: Person installing patches to the OMS core and plug-in homes.
Local OMS: OMS instance on which the administrator runs OMSPatcher.
Remote OMS: OMS instances on other machines (within the same OMS domain as the local OMS) where the administrator has not started any patching operations.
Figure 24-1 Simple Multi-OMS System
For a single OMS system (primary), OMSPatcher will execute the patching steps. For a multi-OMS UNIX system, OMSPatcher generates bash scripts for execution, one per OMS instance; follow the instructions given by OMSPatcher to find those scripts. For Windows multi-OMS systems, OMSPatcher will generate customized patching instructions/commands for the environment in text and HTML formats; administrators must execute these instructions to patch the various Oracle Management Services.
Apart from the target or instance-based configuration, OMSPatcher utilizes installation configuration relationships established in the NextGen OUI inventory as core and plug-in feature-sets. A typical OMS 13c home is organized as follows:
<Middleware Home>
|_____<CORE_BITS>
|_____<PLUGINS_DIRECTORY>
|_____oracle.sysman.db.oms.plugin_13.2.1.0.0
|_____oracle.sysman.emas.oms.plugin_13.2.1.0.0
|_____oracle.sysman.mos.oms.plugin_13.2.1.0.0
Beginning with Enterprise Manager Release 12.1.0.3, Enterprise Manager patches have been converted to a System patch format in order to support patch automation.
What is a System Patch?
A System patch contains several sub-patches whose locations are determined by a file called bundle.xml in the top level directory of the patch. The sub-patches are intended for different sub-systems of a system that correspond with the OMS core and plug-in home organization.
A typical System patch format is organized as follows:
<System patch location - directory>
|_____ Readme.txt (or) Readme.html
bundle.xml
automation
|_____ apply_automation.xml
|_____rollback_automation.xml
Sub-patch1
|_____ etc
|_____config
|_____ inventory.xml
|_____ actions.xml
|_____ artifact_apply.xml
|_____ artifact_rollback.xml
|_____ files/Subpatch1 'payload'
Sub-patch2
|_____ etc
|_____config
|_____ inventory.xml
|_____ actions.xml
For Enterprise Manager release 12.1.0.2 or below, OMSPatcher (earlier known as opatchauto) is not supported for the released one-off patches. For these older releases, you must use OPatch and follow the patch README instructions.
OMSPatcher supports rolling mode only for System patches without any automation (binary-only patching through OMSPatcher). For all other artifacts (MRS, SQL), OMSPatcher only supports complete system downtime patching operations.
Refer to the patch README for the explicit information on supported patching methodologies.
OMSPatcher for the Enterprise Manager OMS will prompt for the following input parameters when performing patching operations. These parameters were determined at the time of Enterprise Manager installation.
Oracle WebLogic Admin Sever URL & port number
Oracle WebLogic Administration Server username
Oracle WebLogic Administration Server password
Because OMSPatcher requires this input for each patching operation, OMSPatcher provides the ability to encrypt the username and password via WebLogic encryption APIs and pass this information using a property file when running OMSPatcher apply and rollback operations. The next section discusses how to create a property file.
The automated patching functionality achieved using OMSPatcher expects WebLogic Administration Server URL and credentials as an input for patching and configuration detection operations. Primarily, the WebLogic Administration server is the host that manages the Managed Server where the OMS instance is deployed. If you do not want to set the credentials every time you are prompted while patching the OMS, you can update the property file. OMSPatcher allows you to repeatedly provide the inputs using property file option.
Property file for a Primary OMS and Standby OMS are different, as they are in different domains.
To create an OMSPatcher property file:
Before running an OMSPatcher patching session, you must ensure the following configuration and inventory-based prerequisites are satisfied: Configuration-based conditions that have to be honored for OMS automation is given below.
The Enterprise Manager Software library must be configured.
The Oracle WebLogic Administration Server that controls the OMS instance (currently to be patched) through a managed server must be up and running.
Ensure that the Oracle Database, which houses the OMS Management Repository, and its listener are up and running.
Ensure that you have the latest version of the OMSPatcher in the OMS platform home of each host.
If you do not have the latest OMSPatcher version, follow the instructions outlined in the My Oracle Support note 2135028.1 available at:
https://support.oracle.com/epmos/faces/DocumentDisplay?_afrLoop=529643231574036&id=2135028.1&_adf.ctrl-state=c5dyo92tl_489#REF
Check your patch README to determine whether there are any specific prerequisites to be executed based on patch and patching methodologies.
Checking System Prerequisites
To run omspatcher commands, ensure that 'ORACLE_HOME/OMSPatcher is included in the PATH environment variable.
To make sure all prerequisite checks pass and no errors occur during the OMSPatcher patching session, Oracle recommends running the following commands on each OMS instance (in your OMS system).
omspatcher apply <PATCH_LOC> -analyzeMust be run from the System patch location (for apply operations)
OMS systems need not be shut down when running apply -analyze.
Check the Patch README and the instructions given for chosen patching methodologies.
OR
omspatcher rollback -analyze -id <comma (,) separated list of sub-patches to be rolled back for System patch>
In order to roll back all sub-patches together, all sub-patches should be from same system patch.
Example 24-1 OMSPatcher rollback -analyze output
------------------------------- omspatcher rollback -id 1111137 -analyze OMSPatcher Automation Tool Copyright (c) 2015, Oracle Corporation. All rights reserved. OMSPatcher version : 13.8.0.0.0 OUI version : 13.8.0.0.0 Running from : /scratch/mw Log file location : /scratch/mw/cfgtoollogs/omspatcher/1111137_Nov_11_2015_22_54_57/rollback2015-11-11_22-54-57PM_1.log OMSPatcher log file: /scratch/mw/cfgtoollogs/omspatcher/SystemPatch/omspatcher_2015-11-11_22-55-02PM_analyze.log Please enter OMS weblogic admin server URL(t3s://myserver.myco.com:7101):> Please enter OMS weblogic admin server username(weblogic):> Please enter OMS weblogic admin server password:> Sub-patch(es) " 1111137 " are part of the OMS System patch. Oracle Home: /scratch/mw, Sub-patch(es): [1111137, 1111126] Do you want to rollback sub-patch(es) "1111137" only? [y|n] y User Responded with: Y Configuration Validation: Success Running rollback prerequisite checks for patch(es) "1111137" and Oracle Home "/scratch/mw"... Sub-patch(es) "1111137" are successfully analyzed for Oracle Home "/scratch/mw" Complete Summary ================ All log file names referenced below can be accessed from the directory "/scratch/mw/cfgtoollogs/omspatcher/2015-11-11_22-54-57PM_SystemPatch_1111192_1" Prerequisites analysis summary: ------------------------------- The following sub-patch(es) are rollbackable: Featureset Sub-patches Log file ---------- ----------- -------- oracle.sysman.top.oms 1111137 1111137_RollbackPrereq2015-11-11_22-55-25PM_2.log Log file location: /scratch/mw/cfgtoollogs/omspatcher/SystemPatch/omspatcher_2015-11-11_22-55-02PM_analyze.log OMSPatcher succeeded. bash-3.2$
Once the analysis finishes, you can refer to the OMSPatcher log to see what steps would be executed by OMSPatcher in non -analyze mode. The log file contains references to the HTML and text output file HTML containing detailed steps.
OMSPatcher must be run from the platform home of the OMS being patched. To run OMSPatcher commands from any directory include <ORACLE_HOME__PATH>/OMSPatcher in the PATH environment variable. The ORACLE_HOME environment variable must be set as the platform home or provided using the omspatcher "–oh" option. For example:
omspatcher apply <patch>Minimum Required OMSPatcher Version: 13.8.0.0.0
Ensuring You Have the Latest Version of OMSPatcher
OMSPatcher is the patching utility that executes end to end patching procedure for OMS Patches. Ensure that the latest version of OMSPatcher is available on all instances of OMS platform homes.
To check the version of OMSPatcher residing on the system, run the following command:
omspatcher versionTo get the latest OMSPatcher version, follow the instructions outlined in the My Oracle Support note 2135028.1 available at:
https://support.oracle.com/epmos/faces/DocumentDisplay?_afrLoop=277259559046496&id=2135028.1&_afrWindowMode=0&_adf.ctrl-state=4eefxg576_200
Ensuring You Have the Latest Version of OPatch
OMSPatcher uses the OPatch utility to apply the patch. For this reason, you must ensure that you have the latest version of OPatch on all instance of OMS platform homes. To check the version of OPatch residing on the system, run the following command. Ensure to execute the command after including ORACLE_HOME/OPatch in the PATH environment variable.
opatch versionTo download the latest version of OPatch, follow the instructions outlined in the My Oracle Support note 224346.1 available at the following location:
https://support.oracle.com/CSP/main/article?cmd=show&type=NOT&id=224346.1
Minimum Required OPatch Version: 13.8.0.0.0
Patching Quickstart
Using OMSPatcher typically involves the following phases:
1. Determining Whether Your System Meets OMSPatcher System Requirements
Run omspatcher apply -analyze
The apply -analyze command simulates an OMSPatcher apply session by running all prerequisite checks, when possible, without making changes to the system (either bits or configurations). This command does not apply the patch.
See "Prerequisites for Running OMSPatcher" for additional information.
2. Determining What System Patches Currently Exist on Your System
Run omspatcher lspatches
See "lspatches" for more information.
3. Obtaining Patches from My Oracle Support (MOS)
OMSPatcher requires that the required platform or plug-in System patches be obtained from My Oracle Support and downloaded to the OMS instance on which OMSPatcher is to be run.
See "My Oracle Support: Searching for Patches" for more information.
4. Applying a Patch
Run omspatcher apply <patch>
The apply command applies all patches within a specified System patch to the platform home from which omspatcher command is run.
See "Running omspatcher apply" for more information.
5. Deinstalling Individual Sub-patches of a System Patch
Run omspatcher rollback -id <list of comma separated sub-patches of System patch>
For a complete list of sub-patches of the System patch, refer to the patch README.
If, after applying the patch, the system is not stable, the most likely cause is the patch itself. Contact Oracle Support. They will recommend that you remove the patch using the omspatcher rollback command.
See "Running omspatcher rollback" for more information.
The first step in the patching process is to determine what patches you need from My Oracle Support (MOS). MOS is the single source of truth for patching. You can access MOS at the following location:
Once you have logged in, you have access to interactive support tools and information that simplify searching for and obtaining the requisite patches for your Oracle environment. .
My Oracle Support contains many features and capabilities that are grouped under tabs across the top of the application. Of primary interest is the Patches and Updates tab. From this tab you can search for the patches based on the OMS patch area (core, plug-in, or combination).
omspatcher applyOnce you have downloaded the patch, see the patch README for explicit patch details and instructions on applying the patch. You can find the README at the following location
<System patch location>/README.txt (or) README.html
As you step through the patching operations in the README, running omspatcher apply (depending on the configuration that is patched, primary or standby) will generate a custom, environment-specific version of the README for patching operations for the primary site multi-OMS or standby site OMS systems. For a primary site single OMS system, running omspatcher apply will perform patching and deployment operations.
On your local OMS instance, run the following command from the top level System patch directory:
Unlike omspatcher analyze, you should not run omspatcher apply on every OMS instance. OMSPatcher will either execute all patching and deployment operations, or will generate environment-specific steps that include complete configuration aspects of the System.
For a multi-OMS UNIX system, OMSPatcher generates bash scripts for execution, one per OMS instance; follow the instructions given by OMSpatcher to find those scripts. For Windows multi-OMS systems, OMSpatcher will generate customized patching instructions/commands for the environment in text and HTML formats; administrators must execute these instructions to patch the various OMSs.
omspatcher rollbackSee the patch README for explicit patch details and instructions on deinstalling the patch. You can find the README at the following location
As you step through the patch deinstallation operations in the README, running omspatcher rollback (depending on the configuration that is patched, primary or standby) will generate a custom, environment-specific version of the README for patching operations for the primary site multi-OMS or standby site OMS systems. For a primary site single OMS system, running omspatcher rollback will perform the deinstallation operations.
Unlike omspatcher analyze, you should not execute the omspatcher rollback command on every OMS instance. OMSPatcher will either execute all patching and deployment operations, or will generate environment-specific steps that include complete configuration aspects of the System.
The list of sub-patches within the System patch can be retrieved from patch README.
The list of sub-patches listed in System patch README may differ from the patches that are actually installed. During System patch installation, some sub-patches may be skipped (not installed).
For a multi-OMS UNIX system, OMSPatcher generates bash scripts for execution, one per OMS instance; follow the instructions given by omspatcher to find those scripts. For Windows multi-OMS systems, OMSPatcher will generate customized patching instructions/commands for the environment in text and HTML formats; administrators must execute these instructions to patch the various OMSs.
omspatcher lspatchesAfter the patch is applied or rolled back, you can run the omspatcher lspatches command to generate a comprehensive Component type - patches map of the OMS homes and installed patches.
omspatcher versionTo determine the version numbers of the various OMSPatcher utilities (OPlan, OsysModel) that reside on your system, you can run omspatcher version.
If you have configured a standby OMS for High Availability, refer to the chapter on "Enterprise Manager Disaster Recovery" and the appendix on Standby OMSs Using Standby WebLogic Domain" both of which can be found in the Oracle Enterprise Manager Advanced Installation and Configuration Guide.
This section provides a comprehensive listing and description of all OMSPatcher commands used to patch an OMS.
OMSPatcher commands must be run from the OMS Middleware home.
OMSPatcher Commands
The OMSPatcher commands are run from the OMS Middleware home out of the OMSPatcher directory. The Middleware home must be set as $ORACLE_HOME. In the following generic example, an OMSPatcher command is run from a Middleware home.
omspatcher apply <PATH_TO_PATCH_DIRECTORY>
where <PATH_TO_PATCH_DIRECTORY> is the full path to the System patch top level directory.
You can view online help for any command (except version) by specifying the -help option.
Copyright (c) 2016, Oracle Corporation. All rights reserved.
Usage: omspatcher [ -help ] [ -analyze ] [ command ]
command := apply
rollback
checkApplicable
lspatches
version
saveConfigurationSnapshot
<global_arguments> := -help Displays the help message for the command.
-analyze Print the actions, steps to be performed without any execution.
example:
'omspatcher -help'
'omspatcher apply -help'
'omspatcher rollback -help'
'omspatcher checkApplicable -help'
'omspatcher lspatches -help'
'omspatcher saveConfigurationSnapshot -help'
omspatcher consists of six primary commands.
apply
rollback
checkapplicable
lspatches
version
Apply a System patch to OMS instance homes. You must specify the patch location or the current directory will be used as the patch location.
OMSPatcher must be run from the platform home. ORACLE_HOME environment variable must be set as the platform home or provided using the –oh option.
You must run the Apply command directly from the System patch location.
When running omspatcher apply, you will be prompted the following:
WebLogic Admin Server URL of the primary OMS (or standby OMS)
Username and Password
Silent interaction is supported by using the silent and property_file options.The standby option should be used if a stand by OMS system is patched. OMSPatcher can pass 'x=y' properties through the command line. See Table 24-2.
Syntax
omspatcher apply <System patch location> [-custCertPath <Path to customer optional certificate>] [-jre <Path to JRE>] [-nonrolling] [-invPtrLoc <Path to oraInst.loc>] [-property_file <Path to property file>] [-analyze] [-silent] [-oh <Platform home path>] [-standby]
Parameters
Path to the location of the patch. If the patch location is not specified, then the current directory is taken as the patch location. The patch can only be a System patch.
Apply Command Options
Table 24-1 Apply
| Option | Description |
jre |
This option tells OMSPatcher to use JRE (java) from the specified location instead of the default location under Oracle Home. |
invPtrLoc |
Used to locate the oraInst.loc file. Needed when the installation used the -invPtrLoc flag. This should be the path to the oraInst.loc file. |
property_file |
The user-defined property file for OMSPatcher to use. The path to the property file should be absolute. The keys for 'omspatcher' are: 'AdminConfigFile' - Encrypted file for Admin Server user of OMS instance domain. 'AdminKeyFile' - Encrypted file for Admin Server password of OMS instance domain. 'AdminServerURL' - Admin Server URL of OMS instance domain. (Example: t3s://<host address>:<port number>) The Key, value pair is of the format 'x=y' where 'x' is omspatcher understood key and each pair is separated by new line in the property file. This option is typically used for silent operations. This option is very useful for silent mode of 'omspatcher' invocation. In order to create encrypted files for WebLogic admin server username & password. Please use
NOTE: For Windows, please make sure that directories and files in the path are separated by "\\" in the property file. |
analyze |
Just prints out the actions without any configuration/binary change through |
silent |
This suppresses any user-interaction. |
oh |
The location of EM platform home. This overrides the ORACLE_HOME environment variable. |
custCertPath |
This option tells OMSPatcher to use the certificate from the specified location. |
nonrolling |
Apply and deploy the patch in non-rolling fashion, provided it is supported by the patch. |
standby |
This option should be used for standby OMS patching operations. |
Apply Command Properties
Table 24-2 Apply Properties
OMSPatcher.OMS_DISABLE_HOST_CHECK=true |
Used to disable host verification check for WebLogic admin server. Please set this property to true if your OMS configuration is based on virtual host. |
OMSPatcher.OMS_USER=<installed OMS user> |
Use this property if OMSPatcher is not able to get the installed OMS administrator name by itself. This switch is applicable only for Windows. |
OMSPatcher.OMS_SCRIPTS_DIR=<existing directory> |
This switch is applicable only for UNIX systems. By providing an existing directory, the bash scripts produced by OMSPatcher for multi-OMS are copied to a newly created time stamped sub-directory under the directory specified by the administrator. This would help OMS administrator to execute the scripts from pre-determined shared location, if any, rather than manual scripts copied to each OMS box. |
Roll back sub-patches of a System patch from OMS instance home. Administrator specifies the sub-patch IDs of the System patch. You can obtain the sub-patch IDs by running the omspatcher lspatches command. See "Running omspatcher lspatches".
Important: OMSPatcher must be run from the Middleware home. ORACLE_HOME environment variable must be set as platform home or provided via the –oh option.
When running omspatcher rollback, you will be prompted the following:
Syntax
omspatcher rollback -id <sub patches ID of System patch> [-custCertPath <Path to customer optional certificate>] [-idFile <file contains list of sub-patch IDs of System patch>] [-invPtrLoc <Path to oraInst.loc> [-jre <LOC>] [-silent] [-nonrolling] [-property_file <path to property file>] [-analyze] [-oh <Platform home path>] [-standby]
Parameters
Sub patch IDs for the System patch to be rolled back. If you want to rollback a whole System patch, the ids of all sub-patches of that System patch must be specified.
Rollback Options
Table 24-3 Rollback
id |
Use |
idFile |
File that contains the list of sub-patch IDs of a System patch. |
invPtrLoc |
Used to locate the oraInst.loc file. Needed when the installation used the invPtrLoc flag. This should be the path to the oraInst.loc file. |
jre |
This option tells omspatcher to use JRE (java) from the specified location instead of the default location under Oracle Home. |
silent |
This option suppresses any user-interaction. |
nonrolling |
Roll back and deploy the patch in non-rolling fashion, provided it is supported by the patch. |
property_file |
The administrator defined property file for omspatcher to use. The path to the property file should be absolute. The keys for 'omspatcher' are: 'AdminConfigFile' - Encrypted file for Admin Server user of OMS instance domain. 'AdminKeyFile' - Encrypted file for Admin Server password of OMS instance domain. 'AdminServerURL' - Admin Server URL of OMS instance domain. (Example: t3s://<host address>:<port number>) The key value pair is of the format 'x=y' where 'x' is omspatcher understood key and each pair is separated by new line in the property file. This option is typically used for silent operations. This option is very useful for silent mode of 'omspatcher' invocation. In order to create encrypted files for WebLogic admin server username & password, Please use NOTE: For Windows, ensure that directories and files in the path are separated by "\\" in the property file. |
analyze |
Displays out the actions without any configuration/binary change through 'omspatcher'. |
custCertPath |
oh |
standby |
Rollback Command Properties
Table 24-4 Rollback Properties
This switch is applicable only for UNIX systems. By providing an existing directory, the bash scripts produced by OMSPatcher for multi-OMS are copied to a newly created and time stamped sub-directory under the directory specified by the administrator. This would help OMS administrator to execute the scripts from pre-determined shared location, if any, rather than a manual script used to copy to each OMS box. |
Displays the list of patches applied to the OMS home. It will show the component Name/Version, Component Type, System patch, Sub-patch and patch description where patch has been applied. Please note that OMSPatcher will be used to apply only system patches. However the OMS can have one-off patches which would have already been applied at the time of the Enterprise Manager installation. OMSPatcher provides information about whether the patch is a system patch or one-off patch and, if it is the system patch, then it will also show all other patches that are part of that system patch.
Syntax
omspatcher lspatches [ -invPtrLoc <Path to oraInst.loc> ] [-jre <LOC> ] [-oh]
Options
Table 24-5 lspatches
jre |
This |
invPtrLoc |
The |
oh |
The location of Middleware home. This overrides the ORACLE_HOME environment variable. |
The version command shows the current version number of the OPatch utility, dependent OPlan version, and the osysmodel version.
Syntax
omspatcher version [-invPtrLoc <Path to oraInst.loc>]
[-jre <LOC>]
[-oh <ORACLE_HOME>]
[-help] [-h]
Options
The following table describes the options available for the version command.
Table 24-6 version Command Options
-invPtrLoc |
The |
-jre |
This |
-oh |
The |
The checkApplicable command performs prerequisite binary checks on the OMS platform home and plug-in homes to determine the applicability of a System patch and/or the whether sub-patches of the System patch can be rolled back.
Syntax
omspatcher checkApplicable [-id <singleton or System Patch ID to be rolled back>] [-custCertPath <Path to customer optional certificate>] [-invPtrLoc <Path to oraInst.loc>] [-jre <LOC>] [-ph <System patch that is to be installed>] [-silent]
Options
The following table describes the options available for the checkApplicable command.
Table 24-7 checkApplicable Command Options
id |
This option can be used to specify the sub-patch IDs that are to be rolled back from the OMS platform home or plug in homes. |
invPtrLoc |
Used to locate the |
jre |
ph |
This option can be used to specify the path to the patch location. The input must be a System patch location. |
silent |
custCertPath |
The saveConfigurationSnapshot command generates configuration a snapshot for the primary OMS (along with OMS repository) and saves it to an XML file that can be read by OMSPatcher.
If file is not specified, it will be saved to a default file (configData.xml) at the following location
ORACLE_HOME/cfgtoollogs/opatch/sysconfig/configData.xml
When running the saveConfigurationSnapshot command, you will be prompted for the following:
Username and password
You can run the command in silent mode (suppress user interaction) via the silent and property_file options.
This command must be run from an OMS instance belonging to the primary OMS system. If the OMS configuration is running on a virtual host, you must set the OMSPatcher.OMS_DISABLE_HOST_CHECK=true option from the command line.
Syntax
[-configFile <File to save configuration snapshot> ]
[-oh <ORACLE_HOME> ]
[-invPtrLoc <Path to oraInst.loc> ]
[-jre <LOC> ]
[-silent ]
[-property_file <path to file> ]
Options
Table 24-8 saveConfigurationSnapshot Command Options
configFile |
Enables OPatch to write the configuration for the specified product to an XML file. The XML file can only be recognized by Oracle System Model APIs and accessed through via the Enterprise Manager SDK. |
oh |
Specifies the Oracle home to be worked on. The Oracle Home specified takes precedence over the environment variable ORACLE_HOME. |
invPtrLoc |
jre |
Instructs OMSPatcher to use JRE (java) from the specified location instead of the default location under Oracle Home. |
silent |
Suppresses any user-interaction. |
property_file |
The user-defined property file for OMSPatcher to use. The path to the property file must be absolute. The keys for 'OMSPatcher' are:
The Key, value pair is of the format 'x=y' where 'x' is an OMSPatcher understood key and each pair is separated by newline in the property file. The In order to create encrypted files for a WebLogic Admin Server username & password, run the following script:
(createKeys.cmd for Windows) to obtain the files and load them through a custom file using the property_file option. NOTE: For Windows, maker sure that directories, files in the path are separated by "\\" in the property file. |
This chapter describes common OMSPatcher problems that may occur during patching operations or the analyze phase.
This chapter covers the following:
In order for OMSPatcher to fully automate the patching process, it accesses various tools/utilities to carry out different patching tasks in their respective phases. The primary tools/utilities outside of OMSPatcher are:
emctl stop oms - Life cycle
emctl start oms - Life cycle
emctl applypatch, emctl rollbackpatch – Apply, rollback SQL changes in the OMS repository SYSMAN schema respectively
emctl register, emctl deregister – Register, de-register metadata services with the right XMLs for MRS artifacts as per patch metadata instructions respectively
These tools/utilities are accessed during the patching process. Note that failure during invocation of these utilities can also happen and the errors & remedies for those commands are not handled in this document. They need to be followed up with Oracle Support for details. However, OMSPatcher will trap errors from these commands output, push it to appropriate logs and announce it to the administrator and finally to support.
Apart from the above external tools/utilities, OMSPatcher uses the following internal utilities to do binary patching operations. They have separated log files generated by OMSPatcher. The internal utilities are patch binary prerequisite checks and patch binary apply, rollback operations.
This section refers to the information through logs published by OMSPatcher as part of its patching operations. This knowledge is needed for the administrator to obtain the appropriate logs from right area to troubleshoot and inform Oracle Support for further analysis. The following annotated example shows OMSPatcher apply output that displays the various log files that are created when running OMSPatcher.
Sample OMSPatcher apply Output
$ OMSPatcher/omspatcher apply /scratch/dev_patches/13_2/1111191
Running from : /scratch/oms/mw
Log file location : /scratch/oms/mw/cfgtoollogs/omspatcher/opatch2016-05-30_03-21-43AM_1.log
OMSPatcher log file: /scratch/oms/mw/cfgtoollogs/omspatcher/1111191/omspatcher_2016-05-30_03-21-48AM_deploy.log
Please enter OMS weblogic admin server URL(t3s://adc00wve.us.oracle.com:7101):>
Running apply prerequisite checks for sub-patch(es) "1111126,1111155,1111137" and Oracle Home "/scratch/oms/mw"...
To continue, OMSPatcher will do the following:
[Patch and deploy artifacts] : Apply sub-patch(es) [ 1111126 1111137 1111155 ]
Register MRS artifact "eventsaux";
Register MRS artifact "VCPUUtilization";
Register MRS artifact "mpcui"
Do you want to proceed? [y|n]
y
Applying sub-patch(es) "1111126,1111137,1111155"
Please monitor log file: /scratch/oms/mw/cfgtoollogs/opatch/opatch2016-05-30_03-23-31AM_3.log
Registering service "eventsaux" with register file "/scratch/oms/mw/sysman/metadata/events/auxiliary/metric_alert_aux.xml"...
Please monitor log file: /scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1/emctl_register_eventsaux_2016-05-30_03-24-20AM.log
Registering service "VCPUUtilization" with register file "/scratch/oms/mw/plugins/metadata/vcpu/vcpu-exalogic-registration.xml"...
Please monitor log file: /scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1/emctl_register_VCPUUtilization_2016-05-30_03-24-28AM.log
Registering service "mpcui" with register file "/scratch/oms/mw/plugins/test_mpcui_1.xml"...
Please monitor log file: /scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1/emctl_register_mpcui_2016-05-30_03-24-34AM.log
Registering service "mpcui" with register file "/scratch/oms/mw/plugins/test_mpcui_2.xml"...
Please monitor log file: /scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1/emctl_register_mpcui_2016-05-30_03-24-40AM.log
Complete Summary
All log file names referenced below can be accessed from the directory "/scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1"
Patching summary:
Binaries of the following sub-patch(es) have been applied successfully:
oracle.sysman.top.oms_13.2.0.0.0 1111126,1111137,1111155 1111126,1111137,1111155_opatch2016-05-30_03-23-31AM_3.log
Deployment summary:
The following artifact(s) have been successfully deployed:
Artifacts Log file
MRS-eventsaux emctl_register_eventsaux_2016-05-30_03-24-20AM.log
MRS-VCPUUtilization emctl_register_VCPUUtilization_2016-05-30_03-24-28AM.log
MRS-mpcui emctl_register_mpcui_2016-05-30_03-24-34AM.log
MRS-mpcui emctl_register_mpcui_2016-05-30_03-24-40AM.log
Log file location: /scratch/oms/mw/cfgtoollogs/omspatcher/1111191/omspatcher_2016-05-30_03-21-48AM_deploy.log
bash-3.2$
Log output to a consolidated directory
As shown in the example above, there is a reference to pushing all logs to a consolidated log directory. The following line in the trace example shows this consolidation log directory.
... All log file names referenced below can be accessed from the directory "/scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1" ...
This consolidated log directory contains the following files (here with reference to the example for rollback).
$ ls -l /scratch/oms/mw/cfgtoollogs/omspatcher/2016-05-30_03-21-43AM_SystemPatch_1111191_1 -rw-r--r-- 1 skkurapa g900 39975 May 30 03:24 1111126,1111137,1111155_opatch2016-05-30_03-23-31AM_3.log -rw-r--r-- 1 skkurapa g900 13219 May 30 03:24 1111126,1111155,1111137_opatch2016-05-30_03-22-01AM_2.log -rw-r--r-- 1 skkurapa g900 120 May 30 03:22 AdminServerStatusPrerequisites_2016-05-30_03-22-01AM.log -rw-r--r-- 1 skkurapa g900 66 May 30 03:22 RepositoryStatusPrerequisites_2016-05-30_03-22-01AM.log -rw-r--r-- 1 skkurapa g900 71 May 30 03:22 Swlib_Prerequisite_2016-05-30_03-22-01AM.log -rw-r--r-- 1 skkurapa g900 456 May 30 03:24 emctl_register_VCPUUtilization_2016-05-30_03-24-28AM.log -rw-r--r-- 1 skkurapa g900 451 May 30 03:24 emctl_register_eventsaux_2016-05-30_03-24-20AM.log -rw-r--r-- 1 skkurapa g900 418 May 30 03:24 emctl_register_mpcui_2016-05-30_03-24-34AM.log -rw-r--r-- 1 skkurapa g900 418 May 30 03:24 emctl_register_mpcui_2016-05-30_03-24-40AM.log -rw-r--r-- 1 skkurapa g900 12574 May 30 03:24 opatch2016-05-30_03-21-43AM_1.log -rw-r--r-- 1 skkurapa g900 3938 May 30 03:24 temp_apply_automation.xml -rw-r--r-- 1 skkurapa g900 3149 May 30 03:24 temp_rollback_automation.xml
All individual log files of all invocation commands are finally copied to a consolidated place as highlighted above. Each command naming convention is self-explanatory and it indicates the actual operations being performed in automation. The omspatcher log file will refer the individual log files so that administrator can easily connect to individual files to refer to any failure.
If the administrator wants to contact Oracle Support, the administrator must provide the following references to Support.
Administrator interface trace(s).
Consolidated log directory as zip
OPatch log file
OMSPatcher log file
Output of omspatcher lspatches command on all OMS instance homes.
Refer to the following table for common OMSPatcher error codes.
Table 24-9 OMSPatcher Error Codes
| Error Code | Description | Remedy/Suggestion |
231 |
Wrong Oracle WebLogic Administration Server URL and/or invalid credentials |
Correct the interview inputs and run OMSPatcher again. |
234 |
Malformed Oracle WebLogic Administration Server URL |
If the Oracle WebLogic Administration Server URL is already defaulted (value given), type <enter>. If it is not given, construct the Oracle WebLogic Administration Server URL as t3s://<WebLogic Administration Server host address>:<WebLogic Administration Server port> .of the domain that controls the managed server on which the OMS is deployed. |
235 |
Unable to connect to OMS repository |
Check the OMS repository connectivity for SYSMAN administrator and run OMSPatcher again. |
236 |
OUI central inventory read issue |
Check if the OUI inventory is locked by some other processes. Check if OUI inventory is readable. |
238 |
Patch binary prerequisite checks failure |
Check OMSPatcher, OPatch, patch binary prerequisite log files for more details on the errors. If not resolved, contact Oracle Support. |
240 - 251 |
Binary updates (or) deployment failure |
233 |
Software library not configured OMS repository connectivity not achieved. (post successful check of the same during credential inputs Oracle WebLogic Administration Server not reachable (post successful check of the same during credential inputs) |
Check the OMSPatcher log file for the failure. |
The following table lists exit codes for external utilities that OMSPatcher uses for life cycle and deployment. If the deployment (or) life cycle fails through OMSPatcher, the administrator can search individual log files for the error messages shown in the Error Message/Recommendation column.
Table 24-10 OMSPatcher External Utilities Error Codes
| Exit Code | Error Message / Recommendation |
34 |
Displays the usage of the command. |
35 |
Unable to read password! Exiting... |
36 |
Unable to get a connection to the repository! Exiting... |
37 |
The Plug-in is not deployed on this Management Server. The plug-in has to be deployed first to register metadata for that plug-in. |
38 |
Input file does not exist |
39 |
This operation is not supported by service. |
40 |
Metadata operation is skipped. |
41 |
Error occurred during Metadata registration. |
42 |
Error occurred during Metadata de-registration. |
This section provides issue resolution information for special cases when using OMSPatcher. This information will allow the administrator to handle these issues easily with less need for support team intervention.
Windows patching failure due to lock of files by Oracle WebLogic Administration Server
In Windows operating systems, it has been noticed that some of the Enterprise Manager related files (used for patching) are locked by running of Oracle WebLogic Administration Server. As OMSPatcher required Oracle WebLogic Administration Server to be RUNNING for the configuration detection, we need to perform the following steps to make sure that this conflict with respect to environment and patching is removed.
Go to ORACLE_HOME
Run OMSPatcher in non-analyze mode. For further instructions, refer to the patch README and Administrator guide.
Once the OMSPatcher is run in non-analyze mode, it will check if active files are locked by Oracle WebLogic administration server and will provide a prompt as shown below (in silent mode it will be auto-yes):
Running prerequisite checks to verify if any files or services are locked by admin server process... Please monitor OPatch log file: c:\MW_130518\oms\cfgtoollogs\opatch\1111112_Jun_ 26_2014_08_16_19\ApplyPrereq2014-06-26_08-16-57AM_8.log The details are: Following files are active : c:\MW_130518\oms\sysman\jlib\emCoreConsole.jar Due to active files to be patched, OMSPatcher will stop all OMS processes so tha t lock on active files may be released... Do you want to proceed? [y|n] y User Responded with: Y OMSPatcher has stopped all OMS processes successfully.
If there is a failure while stopping OMS processes, OMSPatcher will accordingly error out. Refer to the OMSPatcher log file for details.
OMSPatcher will stop the stack and then ask for a confirmation from the administrator on whether to proceed with prerequisite checks of patch binaries (in silent mode it will be auto-yes):
OMSPatcher has stopped all OMS processes successfully. Please make sure the above listed active files are unlocked by all windows processes. Do you want to proceed? [y|n] y User Responded with: Y
Administrators are requested to use some open source utilities like process explorer and search for file strings given as output in (2) to check if any files are still active. If so, kill the process tree of those files so that OPatch will run the checks, patch, and deploy the automation elements.
OMSPatcher will not attempt to re-start the stack. The administrator must restart the stack as needed.
A complete sample trace of this case is shown below:
C:\MW_130518\oms\OPatch_June26>omspatcher apply ..\patches\cmdRcu\1111112 OMSPatcher Automation Tool Copyright (c) 2016, Oracle Corporation. All rights reserved. OMSPatcher version : 13.8.0.0.0 OUI version : 13.8.0.0.0 Running from : c:\MW_130518\oms Log file location: c:\MW_130518\oms\cfgtoollogs\omspatcher\omspatcher2014-06-26_08-16-19AM_1.log omspatcher log file: c:\MW_130518\oms\cfgtoollogs\omspatcher\1111112\opatch_oms_2014-06-26_08-16-23AM_deploy.log Please enter the WebLogic Admin Server URL for primary OMS:> t3s://example.o racle.com:7101 Please enter the WebLogic Admin Server username for primary OMS:> weblogic Please enter the WebLogic Admin Server password for primary OMS:> Configuration Validation: Success Running prerequisite checks to verify if any files or services are locked by admin server process... Please monitor OPatch log file: c:\MW_130518\oms\cfgtoollogs\omspatcher\1111112_Jun_26_2014_08_16_19\ApplyPrereq2014-06-26_08-16-57AM_8.log The details are: Following files are active: c:\MW_130518\oms\sysman\jlib\emCoreConsole.jar Due to active files to be patched, omspatcher will stop all OMS processes so that lock on active files may be released... Do you want to proceed? [y|n] y User Responded with: Y omspatcher has stopped all OMS processes successfully. omspatcher has stopped all OMS processes successfully. Please make sure the above listed active files are unlocked by all windows processes. Do you want to proceed? [y|n] y User Responded with: Y Running apply prerequisite checks for patch(es) "1111112" and Oracle Home "c:\MW _130518\oms"... Please monitor omspatcher log file: c:\MW_130518\oms\cfgtoollogs\omspatcher\1111112_Jun_26_2014_09_01_33\ApplyPrereq2014-06-26_09-03-41AM_10.log Patches "1111112" are successfully analyzed for Oracle Home "c:\MW_130518\oms" To continue, OMSPatcher will do the following: [Patch and deploy patch(es) binaries] : Apply patch(es) [ 1111112 ] to Oracle Home "c:\MW_130518\oms"; Apply RCU artifact with patch "c:\MW_130518\oms\.omspatcher_storage \1111112_Feb_21_2014_06_30_38\original_patch" Do you want to proceed? [y|n] y User Responded with: Y Applying patch "1111112" to Oracle Home "c:\MW_130518\oms"... Please monitor OMSPatcher log file: c:\MW_130518\oms\cfgtoollogs\omspatcher\1111112_Jun_26_2014_09_01_33\apply2014-06-26_09-04-17AM_12.log Updating repository with RCU reference file "c:\MW_130518\oms\.omspatcher_storage\1111112_Feb_21_2014_06_30_38\original_patch" Copying all logs to: c:\MW_130518\oms\cfgtoollogs\omspatcher\2014-06-26_09-01-32AM_SystemPatch_1111112_1 Patching summary: Following patch(es) are successfully applied (Oracle home:patch list): c:\MW_130518\oms:1111112 Log file location: c:\MW_130518\oms\cfgtoollogs\omspatcher\1111112\omspatcher_oms_2013-06-26_09-01-36AM_deploy.log OMSPatcher succeeded.
This section deals with possible issues you may encounter when running bash scripts generated by OMSPatcher in multi-OMS (UNIX-based systems) environment. The following OMSPatcher-generated output illustrates various script-based issues.
Example 24-2 OMSPatcher Output: Multi-OMS, UNIX-based Environment
omspatcher apply /net/slc09jcy/scratch/patch_2nd_nov/em13_1/bundle_patches/1111191
Running from : /scratch/hkumars/oms_install/mw
Log file location : /scratch/hkumars/oms_install/mw/cfgtoollogs/omspatcher/opatch2015-11-11_23-27-35PM_1.log
OMSPatcher log file: /scratch/hkumars/oms_install/mw/cfgtoollogs/omspatcher/1111191/omspatcher_2015-11-11_23-27-46PM_deploy.log
Please enter OMS weblogic admin server URL(t3s://rwsv1452.myco.com:7101):>
Please enter OMS weblogic admin server username():> weblogic
WARNING: Could not apply the patch "1111155" because the "oracle.samples.xohs.oms.plugin with version 13.1.4.0.0" core component of the OMS or the plug-in for which the patch is intended is either not deployed or deployed with another version in your Enterprise Manager system.
WARNING:You have a multi-OMS setup. The patch application is not complete until the following steps are executed successfully.
Please perform the following steps to complete patching operations.
1. Please copy the script "/scratch/hkumars/oms_install/mw/.omspatcher_storage/oms_session/scripts_2015-11-11_23-28-33/run_script#1_on_host_rwsv1452_us_oracle_com_as_user_hkumars.sh" to "rwsv1452.myco.com" and execute the script on host "rwsv1452.myco.com".
2. Please execute the script "/scratch/hkumars/oms_install/mw/.omspatcher_storage/oms_session/scripts_2015-11-11_23-28-33/run_script#2_on_host_rwsv1451_us_oracle_com_as_user_hkumars.sh" on local host.
Complete Summary
All log file names referenced below can be accessed from the directory "/scratch/hkumars/oms_install/mw/cfgtoollogs/omspatcher/2015-11-11_23-27-35PM_SystemPatch_1111191_1"
Patching summary:
The following sub-patches are incompatible with components installed in the OMS system:
1111155
The following warnings have occurred during OPatch execution:
1) Could not apply the patch "1111155" because the "oracle.samples.xohs.oms.plugin with version 13.1.4.0.0" core component of the OMS or the plug-in for which the patch is intended is either not deployed or deployed with another version in your Enterprise Manager system.
2) You have a multi-OMS setup. The patch application is not complete until the following steps are executed successfully.
OMSPatcher Session completed with warnings.
Log file location: /scratch/hkumars/oms_install/mw/cfgtoollogs/omspatcher/1111191/omspatcher_2015-11-11_23-27-46PM_deploy.log
OMSPatcher completed with warnings.
WARNING: You have a multi-OMS setup. The patch application is not complete until the following steps are executed successfully
This message means that patching and deployment are not complete until the administrator performs the bash script execution instructions generated by OMSPatcher.
The administrator needs to provide the credential while running the OMSPatcher generated bash script on secondary OMS.
Example:
/net/slc00skv/scratch/hkumars/work/omshome1967/.omspatcher_storage/oms_session/scripts_2015-11-19_06-40-51/run_script#1_on_host_slc09pjb_us_oracle_com_as_user_hkumars.sh Verifying embedded script host-address "slc09pjb.myco.com" against the network interface for a match... Trying for a match with: fe80:0:0:0:221:f6ff:fe6f:9ac1%2(fe80:0:0:0:221:f6ff:fe6f:9ac1%2) Trying for a match with: slc09pjb.myco.com(10.248.10.100) Script-host address matched with host network interface. Creating session file /scratch/hkumars/work/omshome1967/.omspatcher_storage/oms_session/oms_session_2015-11-18_22-40-19PM... Copying your script to OMSPatcher defined path /scratch/hkumars/work/omshome1967/.omspatcher_storage/oms_session/scripts_2015-11-19_06-40-51/run_script#1_on_host_slc09pjb_us_oracle_com_as_user_hkumars.sh... The System Patch directory already exists in the machine (this could mean that System Patch is already downloaded). Do you want to overwrite it (y|n)? n User provided n for patch transfer. Ignoring patch transfer... The Patch backup location /scratch/hkumars/work/omshome1967/.omspatcher_storage/1111126_Sep_7_2015_02_06_54/original_patch does not exists in the machine (this could mean that the patch automation data are not present on this host and which is mandatory to rollback this patch later from this host). You need to provide host credential to copy it. Executing command: mkdir -p /scratch/hkumars/work/omshome1967/.omspatcher_storage/1111126_Sep_7_2015_02_06_54;scp -r slc00skv.myco.com:/scratch/hkumars/work/omshome1967/.omspatcher_storage/1111126_Sep_7_2015_02_06_54/original_patch /scratch/hkumars/work/omshome1967/.omspatcher_storage/1111126_Sep_7_2015_02_06_54 hkumars@slc00skv.myco.com's password:
Here, the administrator has to provide the user credential to copy the automation data on the secondary OMS which will be used while rolling back the patches.
Troubleshooting Bash Script Execution
The following section covers the most common issues you may encounter while executing OMSPatcher-generated bash scripts in multi-OMS (UNIX-based) environments.
No Windows Support
Microsoft Windows does not support bash script execution. So, this optimization (steps reduction) is not applicable for Windows OMS PS2 environments. The older context sensitive individual steps output through OMSPatcher remains in Windows.
Bash script program availability
The scripts assume that bash is located at /bin/bash. However, if this is not true, make sure the first line of the scripts are updated with the output of whereis bash.
In-between command failure in bash script
If there is a failure in between execution of commands in the bash script, the script stops running. The OMS administrator must triage the failure and comment out (inserting a hash "#" character at the beginning of a line) the already executed portions of the script and restart the bash script execution. Make sure you do not to comment out prompts and prompt-related code in the script.
Complete execution needed for all bash scripts
ALL bash script steps must be executed. No script and no step within any script can be omitted, even in the event of failures. Patching is correct and complete if and only if all steps of all bash scripts are executed correctly as per the order specification.
Patch location (if mounted)
The patch location input may exist on a mounted location. The bash scripts try to perform a secure copy (SCP) from the local OMS (where the OMSPatcher Perl script was invoked). The SCP attempt could fail if the location is mounted. The bash script will ignore the SCP failure.
OMS repository SYSMAN password and prompts
If the script has automation steps to be executed, it will prompt for sysman password, pay attention to it and provide the requested information.
The bash script prompt will appear as follows:
Please provide credential for OMS repository SYSMAN user:
User Credentials to copy automation metadata files to remote node
While running scripts for remote nodes, user will be prompted to entire user credentials to copy automation metadata files from primary node to this node, please pay attention to this and provide the requested information.
The bash script prompt will appear as:
hkumars@slc00skv.us.oracle.com's password:
Patch Transfer/Download
The script will provide an option to download patch from local OMS to remote nodes (for the scripts that involve remote nodes). If the patch is on shared location (or) already downloaded to a specified location mentioned by the script, a user can choose to input n when prompted, and ignore this transfer.
