| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The deployed Hybrid Cloud JVMD Agents use the Hybrid Cloud Gateway Agents to communicate with an on-premise JVMD Engine. The JVMD Engine that is deployed by default with the 13c OMS is marked as the default end point for all the Hybrid Cloud Gateway Agents deployed in your enterprise. This means that, effectively, all the deployed Hybrid Cloud JVMD Agents will report to the JVMD Engine that is marked as the default end point. To change the default end point to a different JVMD Engine, or to a load balancer that is configured in your enterprise, follow these steps:
