| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
To deploy JVMD Agents on Oracle Cloud virtual hosts, follow these steps:
If you select Expand All from the View menu, you can view the target name, target type, target host, target status, platform, and so on of all the discovered WebLogic Administration Servers and Managed Servers (part of all discovered WebLogic domains).
Select the WebLogic Managed Servers on which you want to deploy JVMD Agents. Click Next.
Click Next.
By default, all JVMD Agents deployed on Oracle Cloud virtual hosts will effectively report to the JVMD Engine marked as the default end point.
To view the default JVMD end point for all the Hybrid Cloud Gateway Agents deployed in your enterprise, on the Application Performance Management page, select JVM Diagnostics Engines, then click Configure. Select the Hybrid Gateways Configuration tab. The default JVMD end point is displayed. For information on how to change the default JVMD end point for the Hybrid Cloud Gateway Agents deployed in your enterprise, see Changing the Default JVMD End Point for Hybrid Cloud Gateway Agents.
Click Next.
Once the JVMD Agent deployment is successful, you can verify the deployment by navigating to the Application Performance Management page, and viewing the Application Performance Management Agents section.
