| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Table E-1 describes the timeout values for Enterprise Manager components.
Table E-1 Time Out Values for Enterprise Manager Components
| Component | Description | Timeout Value (in minutes) | Command |
Number of seconds that an Apache session is kept active. If Apache timeout is set beyond the operating system TCP timeout, it will cause unpredictable results. The operating system timeout is set to 2 hours by default. |
5 mins by default |
Run the following command: $ omsvfy show tcp Parameters Incoming Value -------------------- tcp_keepalive_time 7200 tcp_keepalive_intvl 75 tcp_fin_timeout 60 -------------------- |
This is the If you make changes to the login timeout value, be sure to consider the security implications of leaving your session open for other than the default timeout period. Note: The default timeout value does not apply when you restart the Web server or the OMS. In both of those cases, you will be asked to log in to the Cloud Control Console, regardless of the default timeout value. |
45 min by default |
Run the following command: Then, restart OMS for the value to take effect. |
This is controlled by the variable |
10 min |
None |
