| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The emctl partool utility helps you:
Export deployment procedures, and its associated components and directives as par files
Import par files to the same instance or any other instance of Cloud Control
The different flavors of the emctl partool command are listed below:
emctl partool <deploy|view> -parFile <file> -force(optional)
emctl partool <deploy|view> -parFile <file> -force(optional) -ssPasswd <password>
emctl partool <deploy|view> -parDir <dir> -force(optional)
emctl partool export -guid <procedure guid> -file <file> -displayName <name> -description <desc> -metadataOnly(optional)
emctl partool check
emctl partool help
Table 27-10 lists the EMCTL partool command options.
Table 27-10 EMCTL Partool Command Options
| EMCTL Command Option | Description |
Deploys, displays, or exports the |
Indicates the repository password. |
Forces the |
Checks if the software library is configured. |
f |
Indicates the |
Indicates the |
Displays the help message. |
Indicates the |
Indicates the directory where the |
Filters for metadata-only exports. |
Indicates the procedure |
Indicates the path of the |
Indicates the |
This parameter is optional. This parameter creates an Oracle Wallet with the specified password to store the value of the secret property in the exported software library entity. The user must use the same password while importing the |
For more information on emctl partool command see the topic Using emctl partool Utility in the Oracle Enterprise Manager Lifecycle Management Administrator's Guide.
