Go to primary content
Oracle® Enterprise Manager Cloud Control Administrator's Guide
13c Release 2
E74458-09
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
33.12 About Storage Cluster Membership
You can have a cluster configuration setup with two Oracle ZFS Storage Appliances. When such configuration is in use, you can view the cluster membership information of the two appliances.
33.12.1 Viewing Storage Cluster Membership
To view cluster membership information of the appliances which are in a cluster configuration setup, perform the following steps:
  1. From the Targets menu, select All Targets.
  2. In the left navigation pane, expand Groups, Systems and Services target type.
    You can view a list of cluster targets under Groups, Systems and Services.
  3. Click a specific cluster target under Groups, Systems and Services.
    The target name, target type, and the target status of the selected target is displayed in the right pane.
  4. Click on a specific cluster target name from the list in the right pane.
  5. Click the Target Navigation tab which appears to the left of the cluster drop-down list, as shown in Figure 33-7.
    Figure 33-7 Target Navigation Tab View
  6. Select a specific cluster to view the storage summary details of the cluster. You can view the cluster information in the dashboard, images of the storage appliance which have a cluster configuration setup, different networks and pools information.
