| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
When the various components of Enterprise Manager are configured and running efficiently, the Oracle Management Service gathers large amounts of raw data from the Management Agents running on your managed hosts and loads that data into the Management Repository. This data is the raw information that is later aggregated, organized, and presented to you in the Cloud Control console.
After the Oracle Management Service loads information into the Management Repository, Enterprise Manager aggregates and purges the data over time.
The following sections describe:
Enterprise Manager aggregates collected metric data by hour and by day to enhance query performance and help minimize the size of the Management Repository. Before the data is aggregated, each data point is stored in a raw metric data table. Once a day, the previous day's raw metric data is rolled up, or aggregated, into a one-hour and a one-day table. These hourly and daily records will have hourly and daily metric data averages, minimums, maximums and standard deviations respectively.
After Enterprise Manager aggregates the data, the data is then considered eligible for purging. A certain period of time must pass for data to actually be purged. This period of time is called the retention time.
The raw data, with the highest insert volume, has the shortest default retention time, which is set to 7 days. As a result, 7 days after it is aggregated into a one-hour record, a raw data point is eligible for purging.
This data retention policy varies for JVMD and ADP data.
Hourly aggregate metric data records are purged after 31 days. The highest level of aggregation, one day, is kept for 12 months (roughly 365 days).
The default data retention policies are summarized in Table 20-1.
Table 20-1 Default Repository Purging Policies
| Aggregate Level | Retention Time |
Raw metric data |
7 days |
Hourly aggregated metric data |
31 days |
Daily aggregated metric data |
24 months |
If you have configured and enabled Application Performance Management, Enterprise Manager also gathers, saves, aggregates, and purges response time data. The response time data is purged using policies similar to those used for metric data. The Application Performance Management purging policies are shown in Table 20-2.
Table 20-2 Default Repository Purging Policies for Application Performance Management Data
Raw response time data |
24 hours |
One-hour aggregated response time data |
7 days |
One-hour distribution response time data |
24 hours |
One-day aggregated response time data |
31 days |
One-day distribution aggregated response time data |
31 days |
If you do not want to keep severity data for the default period (6 months), and want to reduce the retention period for the EVENTS purge policy, you can use the following command:
em_purge.modify_purge_policy_group('EVENTS',NULL,*l_new_purge_hours*);
This command will modify only the purge policy group which will affect all the purge policies associated with that group. Note that if a purge policy is associated with a purge group, the retention period is taken as the retention period of the group. When the retention of a purge policy (associated with a purge policy group) is changed, then the retention is determined from the purge policy and not from the purge policy group.
To modify an individual purge policy use the following command:
em_purge.modify_purge_policy( p_policy_name IN VARCHAR2, p_retention_hours IN NUMBER )
You can modify the purge policy and also the partition retention values by choosing Manage Cloud Control from the Setup menu, then selecting Repository. From that page, choose the Schema tab and then make any necessary changes in the Purge Policies section (click Modify) or Partition Retention section.
Events data is partitioned and maintains six months of historical data by default. You can change the default retention period using the procedure described above. The severity data is tied to the events data purge policy and will be adjusted accordingly.
The fixed set of tables affected by this data purge are listed below:
EM_EVENT_SEQUENCES EM_EVENT_RAW EM_EVENT_MSGS EM_EVENT_CONTEXT EM_EVENT_ANNOTATIONS EM_EVENTS_INCIDENT EM_ISSUES_INTERNAL EM_ISSUES_MSG EM_ISSUES_ANNOTATIONS EM_INCIDENT_ISSUE EM_PROBLEM_ISSUE EM_INCIDENTS_PROBLEM
The following list is a dynamic set of tables that store data for different event types supported by Enterprise Manager. This list can vary over time as new event types or unsupported event types are added or removed:
EM_EV_CS_RULE_VIOLATION EM_EV_CS_SCORE EM_EV_JOB_STATUS_CHANGE EM_EV_METRIC_ALERT EM_EV_METRIC_ERROR EM_EV_MEXT_UPDATE EM_EV_MNTR_DISRUPTION EM_EV_SELFUPDATE EM_EV_SLA_ALERT EM_EV_TARGET_AVAILABILITY EM_EV_USER_REPORTED EM_EV_ADP_ALERT EM_EV_APM_KPI_ALERT EM_EV_JVMDIAG_ALERT EM_EV_HA_EVENT
Besides the metric data and Application Performance Monitoring data, other types of Enterprise Manager data accumulates over time in the Management Repository.
For example, the last availability record for a target will also remain in the Management Repository indefinitely, so the last known state of a target is preserved.
The Enterprise Manager default aggregation and purging policies were designed to provide the most available data for analysis while still providing the best performance and least disk-space requirements for the Management Repository. As a result, you should not modify these policies to improve performance or increase your available disk space.
However, if you plan to extract or review the raw or aggregated data using data analysis tools other than Enterprise Manager, you may want to increase the amount of raw or aggregated data available in the Management Repository. You can accomplish this by increasing the retention times for the raw or aggregated data.
A PL/SQL API has been provided to modify the default retention time for the core metric data tables in the Enterprise Manager repository. Table 20-3 shows the default number of partitions retained for each of the three tables and the size of the partitions for each table. The API will allow you to change the number of partitions retained only.
Table 20-3 Core EM Metric Data Tables and Default Data Retention in the Management Repository
| Table Name | Partitions Retained | Partition Size |
7 |
DAY |
32 |
DAY |
24 |
MONTH |
To modify the retention period for any of the above tables, execute the following command:
SQL> execute gc_interval_partition_mgr.set_retention('SYSMAN', <table name>, <number of partitions to retain>);
Replace the <table name> by name of table as listed above. The API will allow you to change the number of partitions retained only.
For example, to modify the default retention time for the table EM_METRIC_VALUES from 7 partitions to 14 partitions, follow these steps:
Enterprise Manager Cloud Control has a default purge policy which removes all finished job details which are older than 30 days. This section provides details for modifying this default purge policy.
The actual purging of completed job history is implemented via a DBMS_SCHEDULER job that runs once a day in the repository database. When the job runs, it looks for finished jobs that are 'n' number of days older than the current time (value of sysdate in the repository database) and deletes these jobs. The value of 'n' is, by default, set to 30 days.
The default purge policy cannot be modified via the Enterprise Manager console, but it can be changed using SQL*Plus.
To modify this purge policy, follow these steps:
Log in to the repository database as the SYSMAN user, via SQL*Plus.
Check the current values for the purge policies using the following command:
SQL> select * from mgmt_job_purge_policies;
POLICY_NAME TIME_FRAME -------------------------------- ---------- SYSPURGE_POLICY 30 REFRESHFROMMETALINKPURGEPOLICY 7 FIXINVENTORYPURGEPOLICY 7 OPATCHPATCHUPDATE_PAPURGEPOLICY 7
The purge policy responsible for the job deletion is called SYSPURGE_POLICY. As seen above, the default value is set to 30 days.
To change the time period, you must drop and recreate the policy with a different time frame:
SQL> execute MGMT_JOBS.drop_purge_policy('SYSPURGE_POLICY');
PL/SQL procedure successfully completed.
SQL> execute MGMT_JOBS.register_purge_policy('SYSPURGE_POLICY', 60, null);
SQL> COMMIT;
Commit complete.
POLICY_NAME TIME_FRAME -------------------------------- ---------- SYSPURGE_POLICY 60 ....
The above commands increase the retention period to 60 days. The time frame can also be reduced below 30 days, depending on the requirement.
You can check when the purge job will be executed next. The actual time that the purge runs is set to 5 AM repository time and can be verified using these steps:
Login to the Repository database using the SYSMAN account.
Execute the following command:
SQL> select job_name,
to_char(last_start_date, 'DD-MON-YY HH24:MI:SS') last_run,
to_char(next_run_date, 'DD-MON-YY HH24:MI:SS') next_run
from all_scheduler_jobs
where job_name ='EM_JOB_PURGE_POLICIES';
JOB_NAME LAST_RUN NEXT_RUN
EM_JOB_PURGE_POLICIES 07-SEP-11 05:00:00
The schedule can also be verified from the Enterprise Manager console by following these steps:
From the Setup menu, select Management Service, then select Repository.
Click the Repository Operations tab.
Find the Next Scheduled Run and Last Scheduled Run information for Job Purge in the list.
Please note that the time of the next scheduled execution of the Job Purge does not represent the cutoff time for the retention period; the cutoff time is determined by the purge policy at the time the Job Purge runs.
Enterprise Manager uses the database scheduler (dbms_scheduler) to run various processes in the repository. When the dbms_scheduler is stopped or has insufficient resources to operate, the Enterprise Manager processes do not run or are delayed. The following is a list of common causes that may prohibit the dbms_scheduler from running normally.
Job Queue Processes
The dbms_scheduler uses a separate job-queue process for each job it runs. The maximum number of these processes is controlled by the database parameter, job_queue_processes. If all processes are in use, no new jobs will be started.
The following query returns the number of currently running jobs.
SQL> SELECT count(*) FROM dba_scheduler_running_jobs;
If the count is close to the setting of job_queue_processes, it could mean that Enterprise Manager dbms_scheduler jobs cannot be started (on time). Determine if any of the running dbms_scheduler jobs are stuck and consider increasing the setting for job_queue_processes.
The dbms_scheduler also depends on the setting of the dbms_scheduler property MAX_JOB_SLAVE_PROCESSES. If the number of running dbms_scheduler jobs exceeds this setting, no new jobs will be started. This attribute can be checked using this query.
SQL> SELECT value FROM dba_scheduler_global_attribute WHERE attribute_name='MAX_JOB_SLAVE_PROCESSES';
If the count equals the number of running dbms_scheduler jobs, then determine if any of the running dbms_scheduler jobs are stuck and consult the dbms_scheduler documentation about how to adjust this attribute.
DBMS_SCHEDULER Program Disabled
The dbms_scheduler has an attribute that can be set to disable this feature in the database. When set, the Enterprise Manager dbms_scheduler jobs will not run. To check if this attribute has been set (inadvertently), run this query.
SQL> SELECT * FROM dba_scheduler_global_attribute WHERE attribute_name = 'SCHEDULER_DISABLED';
When a row is returned, the dbms_scheduler is disabled. Execute dbms_scheduler.set_scheduler_attribute('SCHEDULER_DISABLED', 'FALSE');
Consult the dbms_scheduler documentation about how to remove this attribute.
Too Many Database Sessions
Each dbms_scheduler job requires two database sessions. When no more sessions are available, Enterprise Manager dbms_scheduler jobs will not run. The following two queries give the maximum number of allowed sessions and the current number of active sessions:
SQL> SELECT value FROM v$parameter WHERE name='sessions';
SQL> SELECT count(*)FROM v$session;
When the current number of sessions approaches the maximum, then you should determine if any of the sessions are stuck and consult the Oracle Database documentation about how to increase the maximum number of sessions.
Also the high water mark of the number of sessions may indicate that this issue has played a role in the past:
SQL> select * from v$resource_limit where resource_name = 'sessions' ;
If the MAX_UTILIZATION column indicates a value that is close the maximum number of sessions, it could explain why some of the Enterprise Manager dbms_scheduler jobs may not have run (on time) in the past.
Insufficient Memory
The database may not be able to spawn a new job queue process when there is insufficient memory available. The following message in the database alert file, Unable to spawn jobq slave processes, in combination with, (free memory = 0.00M), would be indicative of this problem. Please consult the Oracle Database documentation about how to diagnose this memory problem further.
