| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Performance and resource metrics provide details on the kernel configuration and performance, helping you to identify issues. The CPU Load chart and Free Memory chart enable you to easily view the status. High level CPU and Memory usage are available in the Summary tab with more details in the CPU and Host Memory tabs.
CPU data for the following metrics is collected every 15 minutes and appears in the CPU tab:
The following options are available for you to view kernel information:
Shared memory
CPU I/O wait and buffer cache read/write details
Physical I/O read/write, disk and disk block read/writes
Run queue length and paging activity
Tunable kernel parameters
Resource metrics provides details on the operating system, the available resources, and the load on the operating system or zone.
The following details are available:
Memory, total and available
Swap, total configured and available
CPU details, including the vendor name, number, frequency, revision and mask
Number of cores and threads per CPU
Bar chart showing the utilization percentage per CPU thread
The amount of time spent by all CPUs in different frequencies for Oracle Solaris
CPU and memory usage over time
The CPU Utilization metric displays the percentage utilization of a CPU over time for Oracle Solaris and Linux targets. An abnormally high value indicates that the system is under heavy load. If the value is consistently high, consider reducing the load on the system.
CPU data is collected every 15 minutes. The default display is a graphical representation of the Run Queue Length with a red line for the 1 minute average, a green line for the 5 minute average, and a yellow line for the 15 minute average. To display the information in table format, click Table View.
The CPU Threads Utilization metric collects CPU thread diagnostics for Oracle Solaris and Linux targets, useful for analysis of multi-threaded CPUs. You can view the efficiency and the metrics for each CPU thread.
To help you to gauge the efficiency, the following charts are available:
Bar chart showing the number of CPU threads at each frequency
Historical charts showing the percentage of time spent at different frequencies
In addition to the CPU Utilization, you can view the following processor group utilization details for Oracle Solaris 11 operating systems:
List of processor groups and the number of threads per group
Bar chart of CPU utilization per processor group
Type of group, such as integer pipeline
