| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Following are the log files you can check if the Oracle Management Service (OMS) fails to start:
Oracle Management Service Fails to Start
Check the logs located as indicated in Table 27-11. The INSTANCE_HOME mentioned in the table is the OMS instance home and n is the index of the OMS server.
Table 27-11 OMS Log Files Location
| OMS Log File | Log File Location |
EMCTL log file |
$INSTANCE_HOME/sysman/log/emctl.log file |
Managed Server log files |
$INSTANCE_HOME/user_projects/domains/<DOMAIN_NAME>/servers/EMGC_OMS<n>/logs/EMGC_OMS<n>.log $INSTANCE_HOME/user_projects/domains/<DOMAIN_NAME>/servers/EMGC_OMS<n>/logs/EMGC_OMS<n>.out |
OMS log files |
$INSTANCE_HOME/sysman/log/emoms_pbs.log $INSTANCE_HOME/sysman/log/emoms_pbs.trc $INSTANCE_HOME/sysman/log/emoms.trc $INSTANCE_HOME/sysman/log/emoms.log |
Node Manager log files |
$INSTANCE_HOME/NodeManager/emnodemanager/nodemanager.log |
WebTier Service Fails to Start
Check logs under <WebTier Instance Home>/diagnostics folder in case WebTier start fails.
