| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
Table 27-8 lists the EMCTL resync commands.
Table 27-8 EMCTL Resync Commands
| EMCTL Commands | Description |
Submits a repository re-synchronization operation. When the The Note: To use this command shut down the OMSes first and then submit the |
Aborts the currently running repository re-synchronization operation. The |
Lists the status of the given repository re-synchronization operation. |
