This chapter describes creating APIs using the Oracle Service Bus console.
The following topics are covered:
You access the Oracle Service Bus Console from a web browser.
To start the Oracle Service Bus Console:
WSDL-based SOAP proxy services and REST proxy services created in Oracle Service Bus are able to be published as APIs to the API Manager Portal. You use Service Bus capabilities to create proxy services before adding decorative metadata and publishing the proxy service as an API on the API Manager Portal.
Proxy services configured with deprecated WLS 9 policies can not be published as APIs.
See Developing Services with Oracle Service Bus for more information about developing services with Service Bus.
You can also import a configuration JAR containing proxy services from an existing Service Bus instance. See Importing and Exporting APIs and API Curation Metadata for more information.
You still must add metadata and publish proxy services added using this method.
After populating Service Bus with proxy services, please ensure that you activate the session. After activating the session, select a SOAP- or REST-based proxy service in the Navigator to view the API tab. Note that the API tab is only visible for SOAP- and REST-based proxy services. Complete the task described in Activating the Session to make the API tab visible in the Service Bus console.
After you have created your API proxy service, you must activate the session before adding metadata to and publishing an API for use with the API Manager Portal. The API tab is not visible in the Service Bus console until you complete this task.
Even though the service has been activated, it will not receive any traffic until it is published. You must curate and publish your APIs, as described in Curating and Publishing Your APIs Using Oracle Service Bus, before the services will receive traffic.
Next steps include adding metadata and publishing APIs to theAPI Manager Portal.
