This chapter provides a reference to the elements of the deployment.xsd schema. The deployment.xsd schema is behind the XML with which you configure Oracle Stream Analytics application deployment.
This chapter includes the following sections:
Oracle Stream Analytics provides a number of application assembly elements that you use in the EPN assembly file of your application to register event types, declare the components of the event processing network and specify how they are linked together. The EPN assembly file is an extension to the standard Spring context file.
The Oracle Stream Analytics component configuration elements are organized into the following hierarchy:
beans
Standard Spring and OSGi elements such as bean, osgi-service, and so on.
Use this element to declare an adapter component to the Spring application context. This element has no child elements and the following attributes.
Table 6-1 Attributes of the wlevs:deployment Deployment Element
| Attribute | Description | Data Type | Required? |
Unique identifier for this deployed application. |
Yes. |
The names of the beans that this deployment bean depends on being initialized. The bean factory will guarantee that these beans get initialized before this bean. |
No. |
URL that specifies the location of the bundle that is to be deployed. If a relative URL is specified then the location is relative the For example: location="file:applications/simpleApp/simpleApp.jar" Specifies that the bundle |
No. |
Specifies the state that the bundle should be in once it is deployed to the Oracle Stream Analytics server. The value of this attribute must be one of the following:
Default value: |
No. |
type |
Specifies the type of a bundle. The value of this attribute must be one of the following:
Default value: |
TBundleType |
No |
group-name |
Specifies the name of the cluster group to which the application is deployed. |
String |
No |
start-level |
int |
No |
apply-parameters |
Specifies if application parameters related to an application meta-type resource should be applied. The default behavior is to instantiate only once the first time the application is deployed. |
TapplyParams |
No |
This is how to use the wlevs:deployment element in the deployment file:
<?xml version="1.0" encoding="UTF-8"?>
<beans xmlns="http://www.springframework.org/schema/beans" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:wlevs="http://www.bea.com/ns/wlevs/deployment" xsi:schemaLocation="
http://www.springframework.org/schema/beans/spring-beans.xsd
http://www.bea.com/ns/wlevs/deployment/deployment.xsd">
<bean class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer">
<property name="systemPropertiesModeName" value="SYSTEM_PROPERTIES_MODE_OVERRIDE"/>
</bean>
<wlevs:deployment
id="fx"
state="start"
location="file:${wlevs.domain.home}/applications/fx/com.bea.wlevs.example.fx_11.1.0.0.jar"/>
</beans>
