To run the mapping:
In the Projects tree view, expand the SAP Demo Project
Expand the SDE_SAP_GeoDimension folder.
Expand the Mappings node.
Select the SDE_SAP_GeoDimension.W_GEO_DS mapping.
Right-click and select Execute.
In the Execution window that appears, click OK.
Click OK in the Session Started window.
What happens when you run the mapping?
First, Oracle Data Integrator creates an ABAP program that does the following:
It performs the extraction of the data on the SAP engine. In this example, the extraction joins the two source tables and then returns the joined resultset in an extraction file.
It uploads the extraction file into a FTP data server. This FTP host is specified via the File Logical Schema called File Server for SAP ABAP. This Logical Schema is mapped to a Physical Schema and therefore a data server in the given context. This data server contains the connection information for the FTP host.
Then, the ABAP code is uploaded using the OdiSapAbapExecute tool. The ABAP program is pushed into the SAP Function group given in the SAP_FUNCTION_GROUP LKM option. This phase can be suppressed by setting the UPLOAD_ABAP_CODE LKM option to No.
The ABAP code is executed also by the OdiSapAbapExecute tool. At the end of the ABAP code execution, the extraction file is available in the FTP host.
The Oracle Data Integrator agent is able to download this extraction file from the FTP host, or directly access it, depending on the FTP_TRANSFER_METHOD specified in the IKM option.
Finally, when the agent accesses the extraction file, it uses SQL*Loader or a JDBC Connection to load this file into the Oracle/non-Oracle staging area. The rest of the integration process takes place within the Oracle/non-Oracle engine.
To review the mapping execution:
Connect to Operator.
In the Operator, select the Session List tree view.
Expand the All Executions node in this tree view.
The latest session is the first entry of this list.
Double click the SDE_SAP_GeoDimension.W_GEO_DS node to see the session details and the number of lines processed.
