This chapter provides a reference to conditions in Oracle Continuous Query Language (Oracle CQL). A condition specifies a combination of one or more expressions and logical operators and returns a value of TRUE
, FALSE
, or UNKNOWN
This chapter includes the following sections:
You must use appropriate condition syntax whenever condition
appears in Oracle CQL statements.
You can use a condition in the WHERE
clause of these statements:
SELECT
You can use a condition in any of these clauses of the SELECT
statement:
WHERE
HAVING
See Also:
A condition could be said to be of a logical data type.
The following simple condition always evaluates to TRUE
1 = 1
The following more complex condition adds the salary
value to the commission_pct
value (substituting the value 0 for null using the nvl
function) and determines whether the sum is greater than the number constant 25000:
NVL(salary, 0) + NVL(salary + (salary*commission_pct, 0) > 25000)
Logical conditions can combine multiple conditions into a single condition. For example, you can use the AND
condition to combine two conditions:
(1 = 1) AND (5 < 7)
Here are some valid conditions:
name = 'SMITH' S0.department_id = S2.department_id hire_date > '01-JAN-88' commission_pct IS NULL AND salary = 2100
Precedence is the order in which Oracle Stream Analytics evaluates different conditions in the same expression. When evaluating an expression containing multiple conditions, Oracle Stream Analytics evaluates conditions with higher precedence before evaluating those with lower precedence. Oracle Stream Analytics evaluates conditions with equal precedence from left to right within an expression.
Table 6-1 lists the levels of precedence among Oracle CQL condition from high to low. Conditions listed on the same line have the same precedence. As the table indicates, Oracle evaluates operators before conditions.
Table 6-1 Oracle CQL Condition Precedence
Comparison conditions compare one expression with another. The result of such a comparison can be TRUE
, FALSE
, or NULL
When comparing numeric expressions, Oracle Stream Analytics uses numeric precedence to determine whether the condition compares INTEGER
, FLOAT
, or BIGINT
values.
Two objects of nonscalar type are comparable if they are of the same named type and there is a one-to-one correspondence between their elements.
A comparison condition specifies a comparison with expressions or view results.
Table 6-2 lists comparison conditions.
Table 6-2 Comparison Conditions
condition::=
A logical condition combines the results of two component conditions to produce a single result based on them or to invert the result of a single condition. Table 6-3 lists logical conditions.
Table 6-3 Logical Conditions
Table 6-4 shows the result of applying the NOT
condition to an expression.
Table 6-4 NOT Truth Table
-- | TRUE | FALSE | UNKNOWN |
NOT |
Table 6-5 shows the results of combining the AND
condition to two expressions.
Table 6-5 AND Truth Table
AND | TRUE | FALSE | UNKNOWN |
TRUE |
FALSE |
UNKNOWN |
For example, in the WHERE
clause of the following SELECT
statement, the AND
logical condition returns values only when both product.levelx is BRAND
and v1.prodkey
equals product.prodkey
<view id="v2" schema="region, dollars, month_"><![CDATA[ select v1.region, v1.dollars, v1.month_ from v1, product where product.levelx = "BRAND" and v1.prodkey = product.prodkey ]]></view>
Table 6-6 shows the results of applying OR
to two expressions.
Table 6-6 OR Truth Table
OR | TRUE | FALSE | UNKNOWN |
TRUE |
FALSE |
UNKNOWN |
For example, the following query returns the internal account identifier for RBK
or RBR
accounts with a risk of type 2:
<view id="ValidAccounts" schema="ACCT_INTRL_ID"><![CDATA[ select ACCT_INTRL_ID from Acct where ( ((MANTAS_ACCT_BUS_TYPE_CD = "RBK") OR (MANTAS_ACCT_BUS_TYPE_CD = "RBR")) AND (ACCT_EFCTV_RISK_NB != 2) ) ]]></view>
Table 6-7 shows the results of applying XOR
to two expressions.
Table 6-7 XOR Truth Table
XOR | TRUE | FALSE | UNKNOWN |
TRUE |
FALSE |
UNKNOWN |
For example, the following query returns c1
and c2
when c1
is 15 and c2
is 0.14 or when c1
is 20 and c2
is 100.1, but not both:
<query id="q6"><![CDATA[ select S2.c1, S3.c2 from S2[range 1000], S3[range 1000] where (S2.c1 = 15 and S3.c2 = 0.14) xor (S2.c1 = 20 and S3.c2 = 100.1) ]]></query>
The LIKE
condition specifies a test involving regular expression pattern matching. Whereas the equality operator (=) exactly matches one character value to another, the LIKE
conditions match a portion of one character value to another by searching the first value for the regular expression pattern specified by the second. LIKE
calculates strings using characters as defined by the input character set.
The LIKE
condition with the syntax of the comparison String
supports %
for 0 or more characters and -
for any single character in coherence.
like_condition::=
In this syntax:
arith_expr
is an arithmetic expression whose value is compared to const_string
const_string
is a constant value regular expression to be compared against the arith_expr
If any of arith_expr
or const_string
is null, then the result is unknown.
The const_string
can contain any of the regular expression assertions and quantifiers that java.util.regex
supports: that is, a regular expression that is specified in string form in a syntax similar to that used by Perl.
Table 6-8 describes the LIKE
conditions.
Table 6-8 LIKE Conditions
See Also:
For more information on Perl regular expressions, see http://perldoc.perl.org/perlre.html.
This condition is true for all last_name
values beginning with Ma
last_name LIKE '^Ma'
All of these last_name
values make the condition true:
Mallin, Markle, Marlow, Marvins, Marvis, Matos
Case is significant, so last_name
values beginning with MA
, ma
, and mA
make the condition false.
Consider this condition:
last_name LIKE 'SMITH[A-Za-z]'
This condition is true for these last_name
values:
SMITHE, SMITHY, SMITHS
This condition is false for SMITH
because the [A-Z]
must match exactly one character of the last_name
value.
last_name LIKE 'SMITH[A-Z]+'
but true for these last_name
values because the [A-Z]+
must match 1 or more such characters at the end of the word.
SMITHSTONIAN, SMITHY, SMITHS
For more information, see http://java.sun.com/j2se/1.5.0/docs/api/java/util/regex/Pattern.html
A range condition tests for inclusion in a range.
between_condition::=
Table 6-9 Range Conditions
A NULL
condition tests for nulls. This is the only condition that you should use to test for nulls.
null_conditions::=
Table 6-10 Null Conditions
A compound condition specifies a combination of other conditions.
compound_conditions::=
See Also:
Logical Conditions for more information about NOT
, AND
, and OR
conditions.
You can use the IN
and NOT IN
condition in the following ways:
in_condition_set
: Using IN and NOT IN as a Membership Condition
in_condition_membership
: Using IN and NOT IN as a Membership Condition.
You cannot combine these two usages.
When using the NOT IN
condition, be aware of the effect of null values as NOT IN and Null Values describes.
In this usage, the query will be a SELECT
-FROM
-WHERE
query that either tests whether or not one argument is a member of a list of arguments of the same type or tests whether or not a list of arguments is a member of a set of similar lists.
in_condition_membership::=
non_mt_arg_list_set::=
When you use IN
or NOT IN
to test whether or not a non_mt_arg_list
is a member of a set of similar lists, then you must use a non_mt_arg_list_set
. Each non_mt_arg_list
in the non_mt_arg_list_set
must match the non_mt_arg_list
to the left of the condition in number and type of arguments.
Consider the query Q1
and the data stream S0
. Stream S0
has schema (c1 integer, c2 integer)
. The following example shows the relation that the query returns. In Q1, the non_mt_arg_list_set
is ((50,4),(4,5))
. Note that each non_mt_arg_list
that it contains matches the number and type of arguments in the non_mt_arg_list
to the left of the condition, (c1, c2)
<query id="Q1"><![CDATA[ select c1,c2 from S0[range 1] where (c1,c2) in ((50,4),(4,5)) ]]></query>
Timestamp Tuple 1000 50, 4 2000 30, 6 3000 , 5 4000 22, h 200000000
Timestamp Tuple Kind Tuple 1000: + 50,4 2000: - 50,4
If any item in the list following a NOT
IN
operation evaluates to null, then all stream elements evaluate to FALSE
or UNKNOWN
, and no rows are returned. For example, the following statement returns c1
and c2
if c1
is neither 50 nor 30:
<query id="check_notin1"><![CDATA[ select c1,c2 from S0[range 1] where c1 not in (50, 30) ]]></query>
However, the following statement returns no stream elements:
<query id="check_notin1"><![CDATA[ select c1,c2 from S0[range 1] where c1 not in (50, 30, NULL) ]]></query>
The preceding example returns no stream elements because the WHERE
clause condition evaluates to:
c1 != 50 AND c1 != 30 AND c1 != null
Because the third condition compares c1
with a null, it results in an UNKNOWN
, so the entire expression results in FALSE
(for stream elements with c1
equal to 50 or 30). This behavior can easily be overlooked, especially when the NOT
IN
operator references a view.
Moreover, if a NOT
IN
condition references a view that returns no stream elements at all, then all stream elements will be returned, as shown in the following example. Since V1 returns no stream elements at all, Q1 will return all V2 stream elements.
<view id="V1" schema="c1"><![CDATA[ select * from S1[range 10 slide 10] where 1=2 ]]></view> <view id="V2" schema="c1"><![CDATA[ select * from S1[range 10 slide 10] where c1=2 ]]></view> <query id="Q1"><![CDATA[ V2 not in V1 ]]></query>
