JavaScript is required to interactively collapse and expand the table of contents.
Trusted Extensions Label Administration
Exit Print View
Updated: July 2014
July 2014
Describes how labels are used and are displayed in the Trusted Extensions feature of Oracle Solaris and how to plan labels in your organization. Also describes which parts of the Compartmented Mode Workstation Labeling: Encodings Format guide do not apply to the Trusted Extensions implementation.
