git-show-index
(1)
Name
git-show-index - Show packed archive index
Synopsis
git show-index < idx-file
Description
Git Manual GIT-SHOW-INDEX(1)
NAME
SYNOPSIS
DESCRIPTION
Reads given idx file for packed git archive created with git
pack-objects command, and dumps its contents.
The information it outputs is subset of what you can get
from git verify-pack -v; this command only shows the
packfile offset and SHA1 of each object.
GIT
Part of the git(1) suite
ATTRIBUTES
See attributes(5) for descriptions of the following
attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | developer/versioning/git |
|Stability | Uncommitted |
NOTES
This software was built from source available at
https://java.net/projects/solaris-userland. The original
community source was downloaded from http://git-
core.googlecode.com/files/git-1.7.9.2.tar.gz
Further information about this software can be found on the
open source community website at http://git-scm.com/.
Git 1.7.9.2 Last change: 02/22/2012 1
