man pages section 3: Extended Library Functions, Volume 2
Exit Print View
Updated: July 2014
fmal(3M)
Name
fma, fmaf, fmal - floating-point multiply-add
Synopsis
c99 [ flag... ] file... –lm [ library... ]
#include <math.h>
double fma(double x, double y, double z);
float fmaf(float x, float y, float z);
long double fmal(long double x, long double y, long double z);
Description
These functions compute (x * y) + z, rounded as one ternary operation. They compute the value (as if) to infinite precision and round once to the result format, according to the rounding mode characterized by the value of FLT_ROUNDS.
Return Values
Upon successful completion, these functions return (x * y) + z, rounded as one ternary operation.
If x or y are NaN, a NaN is returned.
If x multiplied by y is an exact infinity and z is also an infinity but with the opposite sign, a domain error occurs and a NaN is returned.
If one of x and y is infinite, the other is 0, and z is not a NaN, a domain error occurs and a NaN is returned.
If x*y is not 0*Inf nor Inf*0 and z is a NaN, a NaN is returned.
Errors
These functions will fail if:
Domain Error
The value of x*y+z is invalid or the value x*y is invalid.
If the integer expression (math_errhandling & MATH_ERREXCEPT) is non-zero, the invalid floating-point exception will be raised.
Range Error
The result overflows.
If the integer expression (math_errhandling & MATH_ERREXCEPT) is non-zero, the overflow floating-point exception will be raised.
Usage
An application wanting to check for exceptions should call feclearexcept(FE_ALL_EXCEPT) before calling these functions. On return, if fetestexcept(FE_INVALID | FE_DIVBYZERO | FE_OVERFLOW | FE_UNDERFLOW) is non-zero, an exception has been raised. An application should either examine the return value or check the floating point exception flags to detect exceptions.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
Standard
See also
feclearexcept(3M), fetestexcept(3M), math.h(3HEAD), attributes(5), standards(5)
