man pages section 3: Extended Library Functions, Volume 2
Exit Print View
Updated: July 2014
vz_abs_(3MVEC)
Name
vz_abs_, vc_abs_ - vector complex absolute value functions
Synopsis
cc [ flag… ] file–lmvec [ library… ]
void vz_abs_(int *n, double complex * restrict z,
     int *stridez, double * restrict y, int *stridey);
void vc_abs_(int *n, float complex * restrict z,
     int *stridez, float * restrict y, int *stridey);
Description
These functions compute the magnitude (or modulus) | z | for an entire vector of values at once. The first parameter specifies the number of values to compute. Subsequent parameters specify the argument and result vectors. Each vector is described by a pointer to the first element and a stride, which is the increment between successive elements.
Specifically, vz_abs_(n, z, sz, y, sy) computes y[i * *sy] = | z[ i * *sz] | for each i = 0, 1, ..., *n - 1. The vc_abs_() function performs the same computation for single precision data.
These functions are not guaranteed to deliver results that are identical to the results of the cabs(3M) functions given the same arguments. Non-exceptional results, however, are accurate to within a unit in the last place.
Usage
The element count *n must be greater than zero. The strides for the argument and result arrays can be arbitrary integers, but the arrays themselves must not be the same or overlap. A zero stride effectively collapses an entire vector into a single element. A negative stride causes a vector to be accessed in descending memory order, but note that the corresponding pointer must still point to the first element of the vector to be used; if the stride is negative, this will be the highest-addressed element in memory. This convention differs from the Level 1 BLAS, in which array parameters always refer to the lowest-addressed element in memory even when negative increments are used.
These functions assume that the default round-to-nearest rounding direction mode is in effect. On x86, these functions also assume that the default round-to-64-bit rounding precision mode is in effect. The result of calling a vector function with a non-default rounding mode in effect is undefined.
These functions handle special cases and exceptions in the spirit of IEEE 754. See cabs(3M) for the results for special cases.
An application wanting to check for exceptions should call feclearexcept(FE_ALL_EXCEPT) before calling these functions. On return, if fetestexcept(FE_INVALID | FE_DIVBYZERO | FE_OVERFLOW | FE_UNDERFLOW) is non-zero, an exception has been raised. The application can then examine the result or argument vectors for exceptional values. Some vector functions can raise the inexact exception even if all elements of the argument array are such that the numerical results are exact.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
cabs(3M), feclearexcept(3M), fetestexcept(3M), attributes (5)
