man pages section 3: Extended Library Functions, Volume 4
Exit Print View
Updated: July 2014
getzonerootbyid(3TSOL)
Name
getzonerootbyid, getzonerootbylabel, getzonerootbyname - map between zone root pathnames and labels
Synopsis
cc [flags...] file... -ltsol [library...]
#include <tsol/label.h>
char *getzonerootbyid(zoneid_t zoneid);
char *getzonerootbylabel(const m_label_t *label);
char *getzonerootbyname(const char *zonename);
Description
The getzonerootbyid() function returns the root pathname of zoneid.
The getzonerootbylabel() function returns the root pathname of the zone whose label is label.
The getzonerootbyname() function returns the root pathname of zonename.
All of these functions require that the specified zone's state is at least ZONE_IS_READY. The zone of the calling process must dominate the specified zone's label, or the calling process must be in the global zone. The returned pathname is relative to the root path of the caller's zone.
Return Values
On successful completion, the getzonerootbyid(), getzonerootbylabel(), and getzonerootbyname() functions return a pointer to a pathname that is allocated within these functions. To free the storage, use free(3C). On failure, these functions return NULL and set errno to indicate the error.
Errors
These functions will fail if:
EFAULT
Invalid argument; pointer location is invalid.
EINVAL
zoneid invalid, or zone not found or not ready.
ENOENT
Zone does not exist.
ENOMEM
Unable to allocate pathname.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See also
Intro(2), free(3C), getzonenamebyid(3C), libtsol(3LIB) , attributes(5), labels(5)
Notes
The functionality described on this manual page is available only if the system is configured with Trusted Extensions.
