man pages section 3: Extended Library Functions, Volume 4
Exit Print View
Updated: July 2014
scf_tmpl_prop_destroy(3SCF)
Name
scf_tmpl_prop_create, scf_tmpl_prop_reset, scf_tmpl_prop_destroy, scf_tmpl_get_by_prop, scf_tmpl_iter_props - template property functions
Synopsis
cc [ flag… ] file–lscf [ library… ]
#include <libscf.h>
scf_prop_tmpl_t *scf_tmpl_prop_create(scf_handle_t *handle);
void scf_tmpl_prop_reset(scf_prop_tmpl_t *prop_tmpl);
void scf_tmpl_prop_destroy(scf_prop_tmpl_t *prop_tmpl);
int scf_tmpl_get_by_prop(scf_pg_tmpl_t *pg_tmpl,
     const char *prop, scf_prop_tmpl_t *prop_tmpl, int flags)
int scf_tmpl_iter_props(scf_pg_tmpl_t *pg_tmpl,
     scf_prop_tmpl_t *prop_tmpl, int flags);
Description
The template property functions locate and give access to metadata about properties. They require that the template for the property group containing the property has already been located by one of the scf_tmpl_pg_create(3SCF) suite of functions.
Once retrieved, the scf_prop_tmpl_t can be explored using the scf_tmpl_prop_name(3SCF) suite of functions.
Before calling scf_tmpl_get_by_prop() or scf_tmpl_iter_props(), the scf_prop_tmpl_t must be allocated by scf_tmpl_prop_create. The scf_prop_tmpl_t can be reset to contain no template information with scf_tmpl_prop_reset(), so that it can be used to start an iteration from scratch. All associated memory can be freed with scf_tmpl_prop_destroy().
The scf_tmpl_get_by_prop() function locates template data about the property name specified.
The scf_tmpl_iter_props() function iterates across all property templates defined in the specified property group template.
The iterator state for scf_tmpl_iter_props() is stored on the property template data structure. The data structure should be allocated with scf_tmpl_prop_create(), and to continue the iteration the previously returned structure should be passed in as an argument.
Return Values
The scf_tmpl_get_by_prop() function returns -1 on failure and 0 on success.
The scf_tmpl_iter_props() function returns 0 for successful iteration to the next item, 1 for iteration successfully reaching its end, and —1 on error.
Errors
The scf_tmpl_get_by_prop() and scf_tmpl_iter_props() functions will fail if:
SCF_ERROR_BACKEND_ACCESS
The storage mechanism that the repository server (svc.configd(1M)) chose for the operation denied access.
SCF_ERROR_CONNECTION_BROKEN
The connection to the repository was lost.
SCF_ERROR_DELETED
The instance or its template property group has been deleted.
SCF_ERROR_HANDLE_DESTROYED
The handle passed in has been destroyed.
SCF_ERROR_INTERNAL
An internal error occurred.
SCF_ERROR_INVALID_ARGUMENT
One of the arguments is invalid.
SCF_ERROR_NO_MEMORY
There is not enough memory to populate the scf_prop_tmpl_t.
SCF_ERROR_NO_RESOURCES
The server does not have adequate resources to complete the request.
SCF_ERROR_NOT_BOUND
The handle is not currently bound.
The scf_tmpl_get_by_prop() function will fail if:
SCF_ERROR_NOT_FOUND
Template object matching property doesn't exist in the repository.
SCF_ERROR_TYPE_MISMATCH
Matching template object is the wrong type in the repository.
SCF_ERROR_PERMISSION_DENIED
The template could not be read due to access restrictions.
SCF_ERROR_TEMPLATE_INVALID
The template data is invalid.
The scf_tmpl_prop_create() function will fail if:
The handle argument is NULL.
SCF_ERROR_NO_MEMORY
There is no memory available.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
Safe
See also
svc.configd(1M), scf_tmpl_pg_create(3SCF), scf_tmpl_prop_name(3SCF), attributes(5), smf_template(5)
