man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_ImageColorXYZ2RGB (3MLIB)
Name
mlib_ImageColorXYZ2RGB - XYZ to RGB color conversion
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageColorXYZ2RGB(mlib_image *dst, const mlib_image *src);
Description
The mlib_ImageColorXYZ2RGB() function performs a color space conversion from CIE XYZ to ITU-R Rec.708 RGB with D64 white point.
The source and destination images must be three-channel images.
It uses the following equation:
|R|   |cmat[0] cmat[1] cmat[2]|   |X|
|G| = |cmat[3] cmat[4] cmat[5]| * |Y|
|B|   |cmat[6] cmat[7] cmat[8]|   |Z|
where
cmat[] = { 3.240479, -1.537150, -0.498535,
          -0.969256,  1.875992,  0.041566,
           0.055648, -0.204043,  1.057311 };
src[x][y] = { X, Y, Z };
dst[x][y] = { R, G, B };
Parameters
The function takes the following arguments:
dst
Pointer to destination image.
src
Pointer to source image.
Return Values
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_ImageColorConvert1(3MLIB), mlib_ImageColorConvert1_Fp(3MLIB), mlib_ImageColorRGB2XYZ(3MLIB), mlib_ImageColorRGB2XYZ_Fp(3MLIB), mlib_ImageColorRGB2YCC(3MLIB), mlib_ImageColorRGB2YCC_Fp(3MLIB), mlib_ImageColorXYZ2RGB_Fp(3MLIB), attributes(5)
