man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalLPCCovarianceInit_S16(3MLIB)
Name
mlib_SignalLPCCovarianceInit_S16, mlib_SignalLPCCovarianceInit_F32 - initialization for covariance method of linear predictive coding
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalLPCCovarianceInit_S16(void *state,
     mlib_s32 length, mlib_s32 order);
mlib_status mlib_SignalLPCCovarianceInit_F32(void *state,
Description
Each function initializes the internal state structure for covariance method of linear predictive coding (LPC).
The init function performs internal state structure allocation and global initialization. Per LPC function call initialization is done in LPC function, so the same internal state structure can be reused for multiple LPC function calls.
Parameters
Each function takes the following arguments:
state
Pointer to the internal state structure.
length
The length of the input signal vector.
order
The order of the linear prediction filter.
Return Values
Each function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalLPCCovariance_S16(3MLIB), mlib_SignalLPCCovarianceFree_S16(3MLIB), attributes(5)
