Transitioning From Oracle® Solaris 10 to Oracle Solaris 11.2
Exit Print View
Updated: December 2014
ZFS Root Pool Device Requirements
In general, root pool devices are relabeled and the root pool is created when the system is installed.
  • In Oracle Solaris 11, an SMI (VTOC) label is applied automatically to the root pool disk or disks during installation on both SPARC and x86 based systems, as shown in the following example output:
    # zpool status rpool
    pool: rpool
    state: ONLINE
    scan: none requested
    config:
    NAME        STATE     READ WRITE CKSUM
    rpool       ONLINE       0     0     0
    c7t0d0s0  ONLINE       0     0     0
  • Starting with Oracle Solaris 11.2, an EFI label is applied automatically to the root pool disk or disks during installation on SPARC based systems with GPT enabled firmware (See Firmware, Disk Labeling, and EEPROM Changes.) and most x86 based systems. Otherwise, a VTOC disk label is installed on the root pool disk, as shown in the following example:
    pool: rpool
    state: ONLINE
    config:
    rpool     ONLINE       0     0     0
    c7t0d0  ONLINE       0     0     0
    When you attach a disk to create a mirrored root pool, use the whole disk syntax.
    # zpool attach rpool c7t0d0 c7t2d0
    Make sure to wait until resilver is done before rebooting.
    The pool remains in a DEGRADED state until the new disk is resilvered.
    pool: rpool
    state: DEGRADED
    status: One or more devices is currently being resilvered.  The pool will
    continue to function in a degraded state.
    action: Wait for the resilver to complete.
    Run 'zpool status -v' to see device specific details.
    scan: resilver in progress since Thu Jan 24 08:15:13 2013
    224M scanned out of 22.0G at 6.59M/s, 0h56m to go
    221M resilvered, 0.99% done
    config:
    rpool       DEGRADED     0     0     0
    mirror-0  DEGRADED     0     0     0
    c7t0d0  ONLINE       0     0     0
    c7t2d0  DEGRADED     0     0     0  (resilvering)
  • The pool must exist either on a disk slice or on disk slices that are mirrored. If you attempt to use an unsupported pool configuration during an beadm operation, you will see a message similar to the following:
    ERROR: ZFS pool name does not support boot environments
  • On an x86 based system, the disk must contain an Oracle Solaris fdisk partition. An Oracle Solaris fdisk partition is created automatically when the x86 based system is installed. See Using the fdisk Option in Managing Devices in Oracle Solaris 11.2 .
For more general information about managing ZFS root pools, see Chapter 4, Managing ZFS Root Pool Components, in Managing ZFS File Systems in Oracle Solaris 11.2 .
