Transitioning From Oracle® Solaris 10 to Oracle Solaris 11.2
Exit Print View
Updated: December 2014
Swap and Dump Device Configuration Changes
Swap space is the reserved area of a disk that the Oracle Solaris OS software and application software can use for temporary storage. Swap space is used as virtual memory storage areas when the system does not have enough physical memory to handle current processes that are running. In Oracle Solaris 10 a UFS root environment provides one disk slice for both swap and dump devices. In Oracle Solaris 11, two separate volumes are created as a swap device and a dump device. In a ZFS root file system, the disk space that is reserved for swap is a ZFS volume. Use the dumpadm command as follows to display this information:
# dumpadm
Dump content: kernel pages
Dump device: /dev/zvol/dsk/rpool/dump (dedicated)
Savecore directory: /var/crash
Savecore enabled: yes
Save compressed: on
# swap -l
swapfile             dev    swaplo   blocks     free
/dev/zvol/dsk/rpool/swap 182,2         8  4061176  4061176
Display information about the swap and dump volume names and sizes as follows:
# zfs list -t volume -r rpool
NAME         USED  AVAIL  REFER  MOUNTPOINT
rpool/dump  4.13G  51.6G  4.00G  -
rpool/swap  4.13G  51.6G  4.00G  -
You can display swap space sizes in human-readable format, as shown in this example:
# swap -sh
total: 1.4G allocated + 227M reserved = 1.6G used, 432G available
# swap -lh
/dev/zvol/dsk/rpool/swap 285,2        8K     4.0G     4.0G
    Managing ZFS swap and dump volumes differs from how you manage a single slice for a UFS swap and dump device in the following ways:
  • You cannot use a single volume for both swap and dump devices in a ZFS root environment.
  • You cannot use a file as swap device in a ZFS root environment.
  • The system requires that the dump device is approximately 1/2 to 3/4 the size of physical memory. If the dump device is too small, you will see an error similar to the following:
    # dumpadm -d /dev/zvol/dsk/rpool/dump
    dumpadm: dump device /dev/zvol/dsk/rpool/dump is too small to hold a system dump
    dump size 36255432704 bytes, device size 34359738368 bytes
You can easily increase the size of the dump device by increasing the volume's volsize property, as shown in the following example, but it might take some time to reinitialize the volume.
# zfs get volsize rpool/dump
NAME        PROPERTY  VALUE  SOURCE
rpool/dump  volsize   1.94G  local
# zfs set volsize=3g rpool/dump
rpool/dump  volsize   3G     local
Changing the size of the swap volume is difficult if the swap device is in use. Consider creating a second swap volume and adding it as a swap device as follows:
# zfs create -V 3G rpool/swap2
# swap -a /dev/zvol/dsk/rpool/swap2
# swap -l
/dev/zvol/dsk/rpool/swap2 182,4         8  6291448  6291448
Then, add an entry for the new swap device in the /etc/vfstab file. For example:
/dev/zvol/dsk/rpool/swap2    -        -       swap    -       no      -
For more information about swap space and dump device configuration, see About Swap Space in Managing File Systems in Oracle Solaris 11.2 .
