Table 87. System Preferences
ActivationLoadBalancerConfig |
For use with the Assignment Manager's load splitter. Set this preference to the Configuration ID for the load splitter configuration that you want to use for activating territory alignments. For more information about load splitter, see Siebel Assignment Manager Administration Guide. For more information about activating territory alignments, see Siebel Territory Management Guide. |
Activity Hierarchy: Max Levels |
The maximum number of levels for the Activity Hierarchy. |
ActivityStatusToCloseVisit |
A visit activity cannot be closed unless all of its required child activities have a status value that matches one of the values in this system preference. (By default, an activity cannot be closed unless all required child activities have been done or canceled.) Default: 'Done','Cancelled' |
Alarm Manager Load Frequency |
Number of minutes the system waits before rechecking for alarms. Default: 60 |
AllowOverReceipts |
If set to TRUE, the received quantity can be greater than the shipped quantity. Also, for an internal order, when the Process Receipt command is invoked, the pick ticket can be closed only when the received quantity is equal to or greater than the shipped quantity. For more information about shipping and receiving, see Siebel Field Service Guide. |
Always Show Message Bar Alerts |
Obsolete. |
AMS * |
All system preferences beginning with AMS are obsolete. |
Auto Mgr Calendar Access |
Allow employee's manager access to the employee's calendar, even if the employee does not explicitly give the manager access. NOTE: If multiple employees share a position, only the calendar of the primary employee is accessible.
Default: True |
Company Name |
See Siebel Pharma Handheld Guide. |
CF_* |
All system preferences beginning with CF_ are used by Captive Finance in Siebel Automotive. Edit these preferences in the Administration - Collections > Collections Preferences view. |
CSM Logging |
Enables logging of merge transactions. Merge transactions are created when connected users combine or merge two or more business components such as accounts or opportunities into one. Information from this log can be used to relink orphaned records created when the merge process is crossed with an update process during a synchronization. This is only applicable if the installation uses Siebel Remote or Replication Manager. Default: False |
DB2: Default Opt Level |
Default optimization level which defines the optimizing algorithm that DB2 will use to execute SQL statements. |
DBX: Vis Rules per Statement 1 |
Number of visibility or routing rules checked per SQL statement processed by the Database Extract component for the first SQL statement with header information. |
DBX: Vis Rules per Statement N |
Number of visibility or routing rules checked per SQL statement processed by the Database Extract component for other SQL statements. |
Default Campaign Source Code |
Default campaign for Web offers used in Siebel Marketing. All offers that are a part of the default campaign will appear in the Featured Offers applet in Siebel Marketing. |
Default EC Procedure |
Obsolete. |
Default MVG Exists Query |
Siebel Industry Applications only: adds an EXISTS statement to every MVG field query. For more information, see Siebel Developer's Reference. Default: TRUE |
Default Offer Code |
Code to track the click path of a customer on the Marketing Web site who does not select a specific offer. |
Default Pricing Procedure |
Obsolete. |
Default Time Zone |
Default time zone for all users of that database. When a user logs in, the Time Zone field of the User business component is checked. If it is empty, the Default Time Zone system preference is checked. Default: UTC |
Docking:Transaction Logging |
Enables docking transaction logging. For more information, see Siebel Remote and Replication Manager Administration Guide. |
eAuc: |
All eAuc: system preferences are obsolete. |
Entitlement: Pricing Dates |
If False or NULL, date verification is skipped when entitlement pricing terms are checked in the Verify Entitlement process. (Similar to the Entitlement: Verify Dates system preference except that one applies to entitlement pricing terms and the other to entitlement service terms.) |
Entitlement: Verify Consumer |
See Siebel Field Service Guide. |
Entitlement: Verify Dates |
Entitlement: Verify Product |
ETL Alignment Version |
See Siebel Data Warehouse Installation and Administration Guide. |
ETL Analysis End ETL Analysis Start ETL Date Format |
ETL Date format indicates the way dates need to be interpreted. The other two parameters mention the date range for which the Exchange Rates will be adjusted. This does not indicate that only the data created within this range will be extracted. Select the earliest date for the Analysis Start Date—that is, when the transactions may have begun. In addition to considering the created and modified dates, consider other relevant dates such as order date. Setting this to an early value such as 19700101 (January 1, 1970) does not affect the processing time. A similar logic applies for choosing Analysis End Date. Note that the values need to be entered in the format defined by ETL Date Format. Default Analysis End: 20101231 Default Analysis Start: 19940101 Default Date Format: YYYYMMDD |
ETL Base Exchange Currency |
Currency in which all the financial data will be converted. While the OLTP supports transactions in many different currencies, the data in the OLAP is converted to a single currency for analysis purposes. The Exchange rates are derived from the Exchange Rates table in the OLTP. Default: USD |
ETL Default Continent |
Value for any address that does not have Continent defined. Set this to a value, which will be used if the value of Continent is not defined in the OLTP. Default: North America |
ETL Default Country |
Value for any address that does not have the Country defined. Set this to a value, which will be used if the value of Country is not defined in the OLTP. Default: USA |
ETL Default Currency |
Value for currency code that will be used if the currency code for a specific financial transaction is not set. Default: USA |
ETL Default Language |
Language code used when language translation occurs when looking up the List of Values table. Default: ENU |
ETL LOV Maximum Value ETL LOV Minimum Value |
In some fields, bucketing of values happens. Instead of saying the number of employees at an account is 45, 96, the values can be bucketed to 0-50, 50-100 and so on. In the List of Values, if the minimum and maximum values are not specified, the values of these parameters will be used. Defaults: 9999999999 and 0 |
ETL Unknown Exchange Rate |
Value used when an exchange rate for a currency to the Datamart Default Currency is undefined in the OLTP. Default: 1 |
FINSeBanking Bill Pay Campaign |
A user property for these applets:
- FINS eBanking Bill Pay Home Campaign Applet
- FINS eBanking Announcements Applet (Bill Pay)
- FINS eBanking Special Offers Applet (Bill Pay)
When this system preference is set to a campaign name, these applets only display offers for that campaign. |
FINSeBanking Campaign |
- FINS eBanking Home Campaign Applet
FINSeEnrollment Campaign |
A user property for the FINS eEnrollment Announcement List Applet. When this system preference is set to a campaign name, the applet only displays Web-Announcements offers for that campaign. |
FINSeSales Campaign |
- FINS Let Us Help You Applet (eSales)
- FINS Whats New In Your Life Applet (eSales)
- FINS eAdvisor Special Offers Applet
Forecast: Auto-Forecast |
Creates subordinates' forecasts to be used in a rollup forecast, if the subordinates have not created forecasts themselves. |
Forecast: Use Server Task |
Send forecast processing requests to the Siebel Server for batch processing. If the value is False, requests are processed locally. |
FSAssetSwap SubComponents |
If set to TRUE, the subcomponent assets of the source asset are shifted to the target asset when an activity part tracker transaction is committed. |
FSDB:Override Service Region |
Maximum monetary value accepted in Auction Item, Bid, and Fee currency fields. |
INSeService Campaign |
A user property for the FINS FSW Announcements Applet. When this system preference is set to a campaign name, the applet only displays Web-Announcements offers for that campaign. |
INSeService Discount Campaign |
A user property for the FINS FSW Health Discount Announcements Applet. When this system preference is set to a campaign name, the applet only displays Web-Announcements offers for that campaign. |
Internal DUNS Number |
Your company's DUNS number. |
LOGMGR:Vis Rules per Statement |
Set to 50 by default. For implementations that use any database other than Oracle, you should change this value to 20. |
Lots For Disperse Only |
See Siebel Life Sciences Guide. |
MRG:Docking Timestamp Source |
See Siebel Remote and Replication Manager Administration Guide. |
MRG:Inter Table Conflict Res |
MRG:Inter Table Merge Rule |
MRG:System Conflict Resolution |
MRG:Txns per Commit |
MRG:User Friendly Notification |
PSP Pricing Var Map - Context |
See Pricing Administration Guide. |
PSP Pricing Var Map - Row Set |
PSP Pricing Var Map - XA |
Quick Print Application |
This preference determines which application is used by quick print. Allowed values are: HTML and EXCEL. This system preference can be overridden by the Quick Print Application user preference. |
Quick Print Output Format |
Set to HTML, CSV, or Tab, as appropriate for the quick print application that you are using. |
ReadOnlyOrderStatus |
If the status of an order matches one of the values in this system preference, then the order becomes read-only when invoiced. Default: 'Booked','Billed' |
RunAlignmentLoadBalancerConfig |
For use with the Assignment Manager's load splitter. Set this preference to the Configuration ID for the load splitter configuration that you want to use for running territory alignments. For more information about load splitter, see Siebel Assignment Manager Administration Guide. For more information about running territory alignments, see Siebel Territory Management Guide. |
SalesHierarchy:UseServerTask |
If set to TRUE, the Sales Hierarchy operation runs as a server task. |
Samples Lots Enabled |
Satmetrix Key Value |
A string provided by Satmetrix to customers of Siebel Satmetrix Surveys. Required for generating encrypted tokens that are part of URLs for displaying survey reports. |
Sch:Break Time Id |
Specifies the Row ID of the work type to be used when calculating the schedule cost where activities contain breaks. The default value is -1. To find the Row ID, navigate to the Application Administration screen > Work Type Administration view, select the record, choose About Record from the Help menu, and note the Row # value. |
Sch:Default Constraint Set |
Specifies the Row ID of the constraint set to be used where no constraint set is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen > Constraint Sets view, select the record, select About Record from the Help menu and note the Row # value. |
Sch:Default Cost Function |
Specifies the Row ID of the cost function to be used where no cost function is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen > Cost Functions view, select the record, select About Record from the Help menu and note the Row # value. |
Sch:Default Parameter Set |
Specifies the Row ID of the parameter set to be used where no cost function is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen > Parameter Sets view, select the record, select About Record from the Help menu and note the Row # value. |
Sch:Default Time Window |
Specifies the Row ID of the time window to be used where no cost function is associated with the service region loaded. The default value is -1. To find the Row ID, navigate to the Scheduling Administration screen > Time Window view, select the record, select About Record from the Help menu and note the Row # value. |
SecThickClientExtAuthent |
See Security Guide for Siebel Business Applications. |
SM WebIntelligence Server |
The URL that points to the Web Intelligence server that serves up reports for Siebel Analytics. |
SqlStyle |
Indicate which SQL statements are to be used with this implementation—Oracle, Microsoft SQL Server, Informix, or Sybase. Case-sensitive. |
SSASqlErrRsltsDiscarded |
This message is displayed to the user when there are more rows than can be returned. For more information, see Implementing Siebel Business Applications on DB2 UDB for z/OS and OS/390. |
SubSqlStyle |
An SQLStyle that falls within a family of similar database products. |
Syndicated Data |
Set to Y to allow syndexp.exe to generate the syndicated data files on the Siebel Server. Syndicated data is only used in the Life Sciences application. |
Target Lists |
Obsolete. |
Technical Support (Alt. 1) |
Specifies the telephone numbers to display in the Siebel Technical Support dialog box. Update this number to match your internal help desk number. The alternate numbers (Alt. 1 and Alt. 2) provide expansion for pager numbers and email addresses. Set a value to None to leave it blank in the dialog box. |
Technical Support (Alt. 2) |
Technical Support (FAX) |
Specifies the fax number to display in the Siebel Technical Support dialog box. Update this number to match your internal help desk fax number. Set a value to None to leave it blank in the dialog box. |
Technical Support (URL) |
Specifies the support URL to display in the Siebel Technical Support dialog box. Update this URL to match your internal help desk Web address. Set a value to None to leave it blank in the dialog box. |
Technical Support (Voice) |
Specifies the voice number to display in the Siebel Technical Support dialog box. Update this number to match your internal help desk number. Set a value to None to leave it blank in the dialog box. |
Time Slice Report Format |
See Product Administration Guide. |
Training: Customer Calendar |
See Siebel Training Guide. |
Training: Employee Calendar |
Training: Partner Calendar |
Training: SCORM Import Path |
Training: SCORM Import URL |
Training: EAI HTTP Password |
Training: EAI HTTP Server |
Training: EAI HTTP User Name |
Training: Lesson Adapter URL |
Training: Lesson Security |
Universal Time Coordinated |
Turns on global time zone support for the entire system. Set this preference to TRUE to enable global time zone support. The default setting is TRUE. NOTE: This is a one-time setting. Once you have turned on global time zone support in a production environment, you should not turn it off.
If you intend to operate your deployment with the Global Time Zone feature enabled, you must also set the operating system of your database servers to UTC time, or its equivalent. Failure to set the OS to UTC when the UTC parameter is set to TRUE will result in asynchronous server request errors. For more information on enabling Global Time Zone, see Global Deployment Guide. Although enabling this feature is optional, it is strongly recommended that you operate your production environment with Global Time Zone enabled. |
UsageTracking Enabled |
See Siebel Content Publishing Guide. |
UsageTracking Log Time Period |
UsageTracking LogFile Dir |
UsageTracking LogFile Encoding |
UsageTracking LogFile Format |
UsageTracking Sess Cache Size |
User Group |
The User Group grantee for database access privileges. It is used in the DDL Sync step in Siebel Tools where the schema for the application is defined. |
