Applications Administration Guide > Configuring the Inbox > Configuring the Toggle Applets for Inbox Views (in Siebel Tools)The Inbox supports dynamic toggle applets in three types of views, see Table 18. Setting up the dynamic applet toggles determines what form applet appears in the lower portion of the Inbox Detail views. In general, you want the applet based on the business object of the underlying feature object. ExampleFor example, if you are setting up the Inbox for service request approvals, you can create a dynamic applet toggle that displays the Service Request Detail Applet form applet (when the business object for the Inbox type is Service Requests). You then create a link between the Inbox business components and the Service Request business component so that the service request information can display in the Inbox detail views. ProcedureTo configure dynamic toggle applets for the Inbox
Applications Administration Guide |
