Applications Administration Guide > Initial Setup >
Setting Up Satmetrix Survey Reports
NOTE:  This section only applies to those who have purchased Siebel Satmetrix Surveys or who have purchased surveys directly from Satmetrix Systems.
In order to view Satmetrix survey reports through your Siebel application, you need to:
  • Add the Account Satmetrix Survey View view to the appropriate user responsibilities. For information about how to add views to responsibilities, see Security Guide for Siebel Business Applications.
  • Enter the secret key string provided by Satmetrix Systems into the Satmetrix Key Value system preference. For information about how to change system preferences, see Setting System Preferences.
  • Extend the List of Values for WI_ARG_TYPE as described in To extend the List of Values for WI_ARG_TYPE.
  • Set up the symbolic URL for access to the Satmetrix reports server, as described in To set up the symbolic URL for access to Satmetrix Reports.
  1. Navigate to Administration - Data > List of Values.
  2. Create a new record and complete the necessary fields.
    Some fields are described in the following table.
    Field
    Value
    Type
    WI_ARG_TYPE
    Display Value
    Satmetrix
    Language-Independent Code
    Satmetrix
    Active
    Yes
    Translate
    Yes
    Replication Level
    All
    For more information about creating List of Values records, see Working with Lists of Values.
  1. Navigate to the Administration - Integration screen > WI Symbolic URL List view.
  2. From the Show drop-down list, select Symbolic URL Application.
  3. In the Symbolic URL list, select SatmetrixSurvey.
  4. Make sure the URL is the URL for the reports server provided by Satmetrix Systems.
  5. In the Symbolic URL Arguments list, complete the fields, using the following table as a guide.
    Name
    Required Argument
    Argument Type
    Argument Value
    Append as Argument
    Sequence
    EncodeUrl
    Yes
    Command
    FALSE
    Yes
    1
    version
    Yes
    Constant
    Obtain from Satmetrix
    Yes
    2
    windowsize
    Yes
    Command
    WebControl width=1000 height=500 border=1
    Yes
    3
    type
    Yes
    Constant
    acct
    Yes
    4
    acctid
    Yes
    Field
    Id
    Yes
    5
    acctname
    Yes
    Field
    Name
    Yes
    6
    contactid
    Yes
    Constant
    Yes
    7
    contactname
    Yes
    Constant
    Yes
    8
    user
    Yes
    Profile Attribute
    Login Name
    Yes
    9
    domain
    Yes
    Constant
    Yes
    10
    model
    Yes
    Constant
    Yes
    11
    created
    Yes
    Field
    Timestamp
    Yes
    12
    token
    No
    Satmetrix
    Satmetrix Surveys, CalculateToken
    Yes
    13
