Applications Administration Guide > References >
Searching for References
Use the All References Read Only and All References Across Organizations Read Only lists to search for references applicable to your accounts. These views are read-only; you cannot modify information, and a contacts list is not available. To use the reference contact information, contact the reference owner, whose User ID appears in the Primary Rep field. To search for references
- Navigate to the References screen > Reference Read Only List view.
As an alternative, select All References Across Organizations Read Only view.
- In the References list, click Query, enter criteria in the query form, and then click Go.
- In the reference record, drill down on the name hyperlink in the Primary Rep field to view reference owner information.
