Siebel Assignment Manager Administration Guide > Working with Dynamic Candidates > Process of Defining Dynamic Candidates >
Mapping Columns From Source Tables to Team-Based Criteria
Using Siebel Tools, you create records in the Dynamic Candidate Component Col object to map columns in a source table, at a particular level in the join, to a team-based assignment criterion. You do so by specifying the attribute column name and the correct assignment criteria attribute name. This task is a step in Process of Defining Dynamic Candidates. Use the following procedure to map columns from source tables to team-based criteria. To map columns from a source table to team-based criterion
- Start Siebel Tools.
- In the Object Explorer, expand Workflow Policy Object, and in the Workflow Policy Objects window, select the object you want to configure.
TIP: If Workflow Policy Object is not visible in the Object Explorer, you can enable it in the Development Tools Options dialog box (View > Options > Object Explorer).
- Lock the project for the object by choosing Tools > Lock Project (or Alt+L).
The pencil icon appears in the W field to indicate the project for the object is locked.
- In the Object Explorer, expand Assignment Object, and then expand Dynamic Candidate.
- Expand the Dynamic Candidate object further, and navigate to Dynamic Candidate Component Col.
- In the Dynamic Candidates Component Columns window, choose Edit > New Record.
- In the new record, enter values for the relevant information.
Table 41 provides descriptions of some of the Dynamic Candidate Component Col object properties.
Table 41. Dynamic Candidate Component Col Object Properties
Assignment Criteria Attribute Name |
The name of the assignment criteria attribute. |
Assignment Criteria Name |
The name of the assignment criteria. NOTE: This property is automatically populated when you select the assignment criteria attribute name.
Inactive |
Indicates if the component is active or inactive. |
Name |
The name of the dynamic candidate component column. |
Parent Name |
The name of the object definition's parent. This is a system-supplied value. |
