Siebel Assignment Manager Administration Guide > Assignment Rule Administration > Process of Defining Assignment WorkloadThere are two methods for defining workload rules—using predefined workload rules or creating your own workload-rule definitions. This topic discusses how to use both options. Assignment Manager provides a set of predefined workload rules that allows you to define workload distribution in assignment rules for employees, positions, or organization. Table 29 lists the predefined assignment workload rules: Optionally, you can create your own workload rules. Use the following procedures to define assignment workload if you plan to create your own workload distribution rules. NOTE: If you plan to use the predefined workload distribution rules, skip to Step 2. |
Siebel Assignment Manager Administration Guide |
