Configuring Siebel eBusiness Applications > Specialized Behavior Supported by Web Templates > About Search and Find in SWE Templates > Search Tag: <swe:srchCategoryControl>Purpose: Displays the control of the search category. In the case of the Advanced Search, it is a check box. Usage: This tag can be called only within the context of a "srchCategory." |
Configuring Siebel eBusiness Applications |
