Configuring Siebel eBusiness Applications > Specialized Behavior Supported by Web Templates > About Search and Find in SWE Templates > Search Result Tag: <swe:srchResultFieldList>Purpose: An iterator tag that encloses all the search result fields that are defined in Tools under a Search Engine Object. The result fields are created dynamically in the buscomp and then displayed on the applet. Usage: This tag establishes a context and encloses the following tags: |
Configuring Siebel eBusiness Applications |
