Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer > Modifying Relationship PropertiesYou can modify the properties of a relationship using the Object List Editor or the Properties Window. For example, you may want to change the text that appears at the end points of a relationship line. NOTE: You cannot modify cardinality using the Object List Editor or the Properties window. If you want to change the cardinality, delete the relationship in the canvas and drag a new one on to it. To modify relationship properties using the Entity Relationship list
To modify the properties of a relationship using the Properties Window
Configuring Siebel eBusiness Applications |
