Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer > Modifying Shape PropertiesYou can modify the appearance of shapes and lines on the ERD canvas. For example, you can highlight an entity by changing the shape's fill colors to something that distinguishes it from the rest. To modify entity or relationship properties
Configuring Siebel eBusiness Applications |
