Configuring Siebel eBusiness Applications > Configuring Screens and Views >
Enabling and Disabling High Interactivity for Views
You can control whether views appear in high interactivity mode by the underlying class definitions of the applets that appear on the view. A view is displayed in high interactivity mode when the underlying classes of the applets in the view have the high interactivity Enabled property set to 2, 3, 4, or 5. The possible values for the high interactivity Enabled property are summarized in Table 46.
Table 46.  High Interactivity Enabled Property Values
Value
Works with High Interactivity
Works with Standard Interactivity
Cachable
1
No
Yes
No
2
Yes
No
Yes
3
Yes
No
No
4
Yes
Yes
Yes
5
Yes
Yes
No
For more information about standard and high interactivity, see About Standard and High Interactivity.
