Developing and Deploying Siebel eBusiness Applications > Using EIM to Load Data Into the Test Environment > Basic EIM Concepts >
Interface Tables
As illustrated in Figure 41, interface tables are intermediate database tables between the Siebel database and another database.
Figure 41.  Process Flows Between Siebel Database and Other Databases
Click for full size image
Rather than loading legacy data directly into Siebel base tables, you or your database administrator first load it into Siebel interface tables using your database-software-specific utility. Then, you use EIM to load data from the interface tables into the Siebel base tables.
