Integration Platform Technologies: Siebel Enterprise Application Integration > Business Services > Creating Business Services in Siebel Tools >
Defining a Business Service in Siebel Tools
You declaratively define the business service in Siebel Tools, and then add your scripts to the business service in the Script Editor.
To define a business service in Siebel Tools
  1. Start Siebel Tools.
  2. Select and lock the project you want to associate your business service with.
    NOTE:  Each business service must belong to a project, and the project must be locked. For information, see Using Siebel Tools.
  3. Select the Business Services object in the Tools Object Explorer.
    The list of predefined business services appears in the right panel.
  4. Choose Edit > New Record to create a new business service.
  5. Type a name for your business service in the Name field.
  6. Type the name of the project you locked in Step 2, in the Project field.
  7. Choose the appropriate class for your business service, from the Class picklist:
    • Data transformation business services must use the CSSEAIDTEScriptService class.
    • Other business services will typically use the CSSService class.
  8. Step off the current record to save your changes.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
