<siebel-xmlext-query-req>
<buscomp id="1">Contact</buscomp>
<remote-source>http://throth/servlet/VBCContacts</remote-source>
<max-rows>6</max-rows>
<search-string>=([Phone] IS NOT NULL) AND ([AccountId] = "1-6")</search-string>
<search-spec>
<node node-type="Binary Operator">AND
<node node-type="Unary Operator">IS NOT NULL
<node node-type="Identifier">Phone</node>
</node>
<node node-type="Binary Operator">=
<node node-type="Identifier">AccountId</node>
<node value-type="TEXT" node-type="Constant">1-6</node>
</node>
</node>
</search-spec>
<sort-spec>
<sort field="Location">ASCENDING</sort>
<sort field="Name">DESCENDING</sort>
</sort-spec>
</Siebel-xmlext-query-req>
