XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters > XML Hierarchy Converter Business Service >
XML Hierarchy to XML Document Method Arguments
Table 25 describes the input arguments for the XML Hierarchy to XML Document method of the XML Hierarchy Converter.
Table 25.  XML Hierarchy to XML Document Method Input Arguments
Display Name
Name
Data Type
Description
Escape Names
EscapeNames
String
Invalid characters in XML tags will be escaped, using Siebel's internal escape format.
n If True, Escape invalid characters (this is the default).
n If False, delete invalid characters. (Do not use in XML tags.)
XML Character Encoding
XMLCharEncoding
String
Outputs the XML character encoding to use. If encoding is blank or not supported, an error is produced.
XML Header Text
XMLHeaderText
String
A string in a local code page character encoding to be inserted before the XML document's root element, after the <?xml...?> declaration. This allows custom processing instructions or an XML header to be inserted before the XML document data starts.
For instance, if the header text is <myheader>data</myheader> and the XML document output without this parameter is <?xml version="1.0" encoding="UTF-8"?><account>..</account>, then the document with the XMLHeaderText included will be:
<?xml version="1.0" encoding="UTF-8"?><myheader>some data</myheader><account>.......</account>
XML Hierarchy
XMLHierarchy
Hierarchy
The XML hierarchy.
Ignore Character Set Conversion Errors
IgnoreCharSetConvErrors
String
Default is False. If the Siebel application cannot represent a given character set—such as the local code page character set—conversion errors are logged, including a warning log entry. When set to True, only a warning message is logged.
Tags on Separate Lines
String
When True, a line feed is placed at the end of each tag. The default is False.
n/a
GenerateProcessingInstructions
String
Default is True. If set to False the Siebel processing instructions are not written. You must manually create and name this input argument if it is required by your business needs.
Table 26 describes the output argument for the XML Hierarchy to XML Document method of the XML Hierarchy Converter.
Table 26.  XML Hierarchy to XML Document Method Output Argument
Display Name
Name
Data Type
Description
XML Document
<Value>
String
The output XML Document.
