XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters >
EAI Integration Object to XML Hierarchy Converter Business Service
There are two methods for the EAI Integration Object to XML Hierarchy Converter, as shown in Table 27. The arguments for each method appear in the tables that follow.
NOTE:  You can use the XML Hierarchy property sets to manipulate in memory XML hierarchies, such as to add new elements, attributes, or envelopes. An XML Hierarchy property set can be converted to and from an Integration Object property set using EAI Integration Object to XML Hierarchy Converter. An XML Hierarchy property set can be converted to and from an XML document using the XML Hierarchy Converter.
Table 27.  EAI Integration Object to XML Hierarchy Converter Methods
Display Name
Name
Description
Integration Object Hierarchy to XML Hierarchy
IntObjHierToXMLHier
Converts an integration object hierarchy to an XML hierarchy.
XML Hierarchy to Integration Object Hierarchy
XMLHierToIntObjHier
Converts an XML hierarchy to an integration object.
