XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters >
XML Converter Business Service
Use the XML Converter when you want to convert any property set to XML, or convert an XML document that is not a Siebel EAI Integration Object Message to a property set.
There are two methods for the XML Hierarchy Converter, as shown in Table 32. The arguments for each method appear in the tables that follow.
Table 32.  XML Converter Methods
Display Name
Name
Description
Property Set to XML
PropSetToXML
Converts a property set hierarchy to XML. Returns the result in the Value field of the Output property set.
XML to Property Set
XMLToPropSet
Converts an XML document stored in the Value field of the property set to a property set hierarchy. Returns the result in the Output property set.
