XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters > EAI Integration Object to XML Hierarchy Converter Business Service >
XML Hierarchy to Integration Object Hierarchy Method Arguments
Table 30 and Table 31 describe the arguments for the XML Hierarchy to Integration Object Hierarchy method of the EAI Integration Object to XML Hierarchy Converter.
Table 30.  XML Hierarchy to Integration Object Hierarchy Input Argument
Display Name
Name
Data Type
Description
Contains Inline Attachments
ContainsInlineAttachments
String
Default is True. DTYPE_ATTACHMENT fields are assumed to include actual attachment content. If False, then the field is treated as a reference to an external attachment.
Integration Object Name
IntObjectName
String
Integration Object Name can be specified if the Siebel Message envelope is not present in the XML hierarchy. The service generates the envelope automatically if this parameter is present.
Strip Name Space
StripNamespace
String
Removes the namespace from XML tags.
Truncate Field Values
TruncateFieldValues
String
Default is True. If True, truncate any fields longer than their maximum size. If True, report fields that are too long as errors.
XML Hierarchy
XMLHierarchy
Hierarchy
The hierarchy to be converted.
n/a
ProcessElementsOnly
String
Default is False. If set to True, processing of attributes is skipped. You must manually create and name this input argument if it is required by your business needs.
Table 31.  XML Hierarchy to Integration Object Hierarchy Output Argument
Display Name
Name
Data Type
Description
SiebelMessage
Hierarchy
The converted integration object.
