XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters > XML Converter Business Service >
XML To Property Set Method Arguments
Table 35 describes the input argument for the XML To Property Set method of the XML Converter.
Table 35.  XML To Property Set Method Input Argument
Display Name
Name
Data Type
Description
XML Document
<Value>
String
The input XML document.
Table 36 describes the output argument for the XML To Property Set method of the XML Converter.
Table 36.  XML To Property Set Method Output Argument
Display Name
Name
Data Type
Description
n/a
Child type of the hierarchical process property containing the entire property set, service method arguments, and child property set.
Hierarchical
The entire output property set. You must manually create and name this output argument if it is required by your business needs.
