Siebel Enterprise Integration Manager Administration Guide > Siebel EIM Tables > EIM Table and Column Mappings >
About Viewing EIM Table Mappings
Before viewing EIM table mappings, you need to make sure your View settings are correct in Siebel Tools so that you can see the appropriate object types in the Object Explorer. For more information, see Verifying Your Object Explorer View Settings.
Information on viewing EIM table mappings is organized as follows:
